Bronco II Ford Bronco II
No signals 85II
Old Mar 6, 2004 | 10:56 AM
ccent's Avatar
ccent
No signals 85II
Hi
My 85II ,The tail and brake lights work as well as the hazards.
All bulbs are good but i have no signals or back up lights
Mysignal light switch is new and works fine i did replace a wire from the rear of the fuse panel that was fried and replaced it.
But with the ignition on and the signal turned on poof goes the fuse(15 amp).
Obviously a short?
I did notice the backup lights and signals share a circuit.
There is also a wire from the signal flasher to the signal and then spliced to the wire going out of the firewall .
Hope i explained this ok!
Thank you
Old Mar 7, 2004 | 11:22 AM
87 XLT's Avatar
87 XLT
If this is wired the same as my 87 you have a VERY strange problem. If you can flash all four turn signal bulbs by turning on the emergency flashers, the turn signals should also work just fine unless the multifnction switch is shorted internally. Is it the multifunction switch thats new?? What does your wiring diagram show is different between E-flashers & turn signals?? When you put it in reverse does the fuse blow? If you remove the turn signal flasher, does the fuse blow?
Old Mar 10, 2004 | 10:43 AM
ccent's Avatar
ccent
Hi thanks for the reply.
Well i got them working .
the truck has 2 flashers .
There was a wire coming off of the flasher and spliced in to the signals wire that was my problem i just un hooked it and they worked i believe it was for some external accessory...
The fuse would only blow when i engaged the turn signal.
Again Thank you ...
CCent
Old Mar 10, 2004 | 10:48 AM
87 XLT's Avatar
87 XLT
Good deal, glad to hear it's fixed.
Evel K
Jun 26, 2014 08:34 AM
1977F250Custom4x4
Nov 25, 2013 08:09 PM
elitelawnteam1
1997 - 2003 F150
Feb 12, 2013 09:50 PM
Zemmeron
Feb 6, 2011 11:01 PM
barefootstu
Electrical Systems/Wiring
18
Jan 28, 2007 12:42 PM
