Sponsored by: Real Truck
Turn Signal Issues
Old Sep 29, 2009 | 04:06 PM
SAE Customs's Avatar
SAE Customs
Turn Signal Issues
I have a 08 f350 sd diesel. My front turn signal flashes fast like a buld is out when i check it appeared that the front left turn was out. But I checked the bulb on the right side of the truck and it worked. I have a plow harness attached to the turn signal wires on both sides. That being said I used a test light to see if that tap had possibly cut the wire or was shorting it. althought even if i completely removed the tap i would get no power to the turn signal wire. I've taken it to the dealership and they said they can't duplicate the problem. HELP.
Old Sep 29, 2009 | 05:10 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE SAE Customs, I moved your question to SuperDuty for a better response from the guys.
Old Sep 29, 2009 | 08:43 PM
BareBones's Avatar
BareBones
Sometimes its just a corroded contact point that's easily correct with a little sandpaper, just be sure to blow it out afterwards. I had a rear turn signal that would fail intermittently in the cold. But of course at twenty below I didn't particularly want to work on it either.....
Old Sep 29, 2009 | 09:01 PM
hcbph's Avatar
hcbph
Turn signals
If by a tap, you're referring to one of those 'pinch on' connectors for adding another wire to an existing circuit, I'd check both at the splice and at the end of the wire. If that's what you have, I'd lay my money on it having cut the conductor in the existing wire.
Paul
Old Sep 29, 2009 | 09:30 PM
SAE Customs
Say the wire was cut. you still get no power of any kind fast or slow flashing on the wire coming from the source pre T-tap.
Old Sep 29, 2009 | 09:32 PM
SAE Customs
I was thinking maybe it had something to do with that smart junctionbox
labman1014
Apr 10, 2011 04:57 PM
undertakerman
Sep 5, 2010 12:52 PM
dwildey
Apr 19, 2010 06:19 AM
mdjwahl
1997 - 2003 F150
Jul 18, 2007 09:50 AM
