Rearend
Old Oct 20, 2005 | 05:54 PM
Poulsom's Avatar
Poulsom
Rearend
I have a 1974 ford truck with a 3:0 rearend and would like to swap it for a 3:5 limited slip. The question is how many spline rearend is it.
Old Oct 20, 2005 | 07:15 PM
Mil1ion's Avatar
Mil1ion
I'm sure it's the same as the 3.00......31 spline.
I assume a 9" rear.
Old Oct 20, 2005 | 07:17 PM
satx77stepside's Avatar
satx77stepside
Pop the axle and count 'em. It's only 4 nuts!
I think your '74 is right around the time they started putting 31 spline in the trucks... maybe '73? I'm not sure, it really would be best just to pull an axle and see what you have. If you're talking about a Bronco you probably have the 28 spline - you didn't specifically say it was a F150.
Old Oct 20, 2005 | 07:20 PM
satx77stepside
Originally Posted by Mil1ion
I assume a 9" rear.
Are all 73-79 non-bronco 9"ers 31 spline?
(Don't know and would like to!! )
Thanks!
Old Oct 21, 2005 | 07:42 AM
MBBFord's Avatar
MBBFord
all the early model broncos had the 28 spline 9" until 71(when they were suposed to come out with the big bronco, but things changed) and after that 71-77 had 31 splines and then the big bronco came out in 78 and had 31 Spline 9" until 82, then they went to the 8.8 rear axle.
Old Oct 21, 2005 | 08:20 AM
KJKozak2's Avatar
KJKozak2
Not in my experience. My 79 F150 4x4 has 28 splines, but my 78 F150 4x4 has 31. Both are factory axles to the best of my knowledge.
I read somewhere that the trucks with the lighter load capacities had 28's, and the heavier trucks had 31's. I can't confirm that though.
The use of 28 and 31 spline axles in F150s seems totally random. I'm guessing that's why most people say to pull the axle and count 'em.
Kevin K.
Old Oct 21, 2005 | 08:29 AM
ford390gashog's Avatar
ford390gashog
yes it all went by GVWR my f150 has 31 splines. your 74 could be either but 28 would be the likely choice.
Old Oct 21, 2005 | 05:33 PM
Bob Crain's Avatar
Bob Crain
I have 1973 XLT 9'' I would like to know what the tag on it means
WDM-AH-3DA and 325 9 328A Is it a trac-loc and what gear ?
Old Oct 21, 2005 | 06:28 PM
RTM's Avatar
RTM
All I can offer with the rear tag info is that you have a 3.25 open, non trac loc carrier.
Old Oct 21, 2005 | 07:50 PM
Polkat's Avatar
Polkat
My '73 9" w/3.50 gears is a 28 spline. The only way to tell for sure, as was mentioned before, is to pop an axle and count them. However, if you have 28, and can find 31 spline axles at the right lengths, and 31 spline side gears, the swap is wasy!
Old Oct 22, 2005 | 10:27 AM
Mil1ion's Avatar
Mil1ion
Actually you don't even have to count them.
If the splines taper down from the smooth machined area it is a 28 spline.
if the splines run without a taper it is a 31 spline.
These WDM-AH-3DA & 328A
are Ford application numbers for bearing sizes & plant codes.
Old Oct 22, 2005 | 11:21 AM
User 71024's Avatar
User 71024
incorrect, my 84 full size bronco had a 9", it's now in my 46 pickup. I found this on the web.
9"
<TABLE style="BORDER-COLLAPSE: collapse" borderColor=#111111 cellSpacing=0 cellPadding=0 width=161 border=0><TBODY><TR><TD style="PADDING-RIGHT: 2px; PADDING-LEFT: 2px; PADDING-BOTTOM: 2px; PADDING-TOP: 2px" align=middle width=103>Vehicle Model</TD><TD style="PADDING-RIGHT: 2px; PADDING-LEFT: 2px; PADDING-BOTTOM: 2px; PADDING-TOP: 2px" align=middle width=50>Year</TD></TR><TR><TD width=107>BRONCO</TD><TD align=middle width=54>67-86</TD></TR><TR><TD width=107>E&F 100&150</TD><TD align=middle width=54>57-86</TD></TR><TR><TD width=107>E200</TD><TD align=middle width=54>68-74</TD></TR></TBODY></TABLE>
Old Oct 22, 2005 | 01:16 PM
MBBFord's Avatar
MBBFord
That the same thing with the transfer cases, they were suposed to have a NP208 until 86, but I have seen people have the borg warner t case in a 84. I have also seen some 8.8 in earlyer models than 86, there was nothing set!
Old Oct 25, 2005 | 04:25 AM
RTM's Avatar
RTM
I am not 100% sure any early bronco got 31 splines axles. I was under the impression that they just got the big bearing and bigger brakes but not 31 spline axles. I'm pretty sure all EB's had 28 spline.
Ford started using the 8.8 around 84 and used both the 9 inch axle and the 8.8 axle until 86 which at that point the 9 inch was fazed out.
bigredofct
New Member Introductions
Nov 21, 2006 08:44 PM
Ford_Eddie_Bauer
Aug 14, 2005 06:47 PM
quickford
Aug 22, 2004 07:25 AM
1949fordf3
Jun 19, 2002 02:27 AM
75fef100xlt
Jun 6, 2001 05:24 AM
