Aerostar Ford Aerostar
neutral safety switch wiring
Old Oct 13, 2005 | 01:02 AM
jimlahey's Avatar
jimlahey
Over the summer, I replace the A4LD automatic trans in my 92 AWD with a Mitsubishi 5-speed from a Bronco II. I have been unable to wire in a neutral safety switch (2 wires on the 5spd but 5 wires on the auto). Apparently, the a4ld's extra wiring will adjust engine idle when you shift out of neutral or park. Since the idle speed in non-adjustable and on the high side, is there any potential problem with keeping the neutral safety button depressed continuously? (possible harm to the computer; obviously there is a safety concern) Thanks for your input!
Old Oct 13, 2005 | 08:26 AM
xuzme720's Avatar
xuzme720
I don't think there's a risk in doing that. since you no longer need the "idle boost", doesn't seem like it should cause any problems, it's only a signal input after all. if nothing else use a relay to depress/energize the neutral switch on start-up. that way it woudn't be energized at all times. not sure if this helps or is even correct, just seems logical to me.
79Ford-4x4
Oct 22, 2019 08:40 PM
1974xlt
May 11, 2017 09:26 AM
Dskeet6
Sep 14, 2010 10:29 PM
beerinside
Aug 11, 2008 10:58 AM
shaun327
Jul 24, 2003 01:23 PM
