Neutral Safety Switch Conversion
Old May 9, 2017 | 08:15 PM
1974xlt's Avatar
1974xlt
I'm putting my '74 2X4 F250 body on a '79 4X4 frame. Do I splice the '74 neutral safety switch wires attached to the steering column to the '79 safety switch harness on the C6 tranny? And does anyone know which wires to connect together?
Old May 10, 2017 | 08:08 AM
F250_Super_4X4's Avatar
F250_Super_4X4
It should be the Red/Blue wire coming from your starter relay post. I did the same as you but opposite. I kept the neutral safety switch on the column and bypassed the switch on the tranny. My thoughts were/are if something goes wrong its right there in the cab
Old May 10, 2017 | 09:57 PM
1974xlt's Avatar
1974xlt
Thanks for the reply. I was led to believe I couldn't use my '74 2X4 steering column with the 4X4 frame set up. Is this incorrect?
Old May 11, 2017 | 12:37 AM
meangreen92's Avatar
meangreen92
Sounds like you could always try stabbing it in, and see for sure.
Old May 11, 2017 | 09:26 AM
jack orchard's Avatar
jack orchard
reback lights will probably need to be rewired, too.,....jack
Chromepro
Jan 22, 2006 08:54 PM
garypettengill
Sep 12, 2005 09:39 PM
mike9762
Dec 12, 2004 06:14 PM
flash-ah-ah
Sep 1, 2003 06:43 PM
strawboss
Sep 28, 1999 09:57 AM
