neutral safety switch
Old Jul 23, 2003 | 08:21 PM
shaun327's Avatar
shaun327
Does anyone know how to by-pass the neutral safety switch on an 89 A4LD trann?....
Old Jul 23, 2003 | 11:57 PM
airharley's Avatar
airharley
cut and jumper or leave open.
Old Jul 24, 2003 | 06:28 AM
Scooter29's Avatar
Scooter29
Un-plug it at the clutch pedal and put in a cut down paper clip. I hated, clutching, braking when stalled on rocks! HEE HEE!
Talk to you guys later....
Old Jul 24, 2003 | 11:47 AM
shaun327's Avatar
shaun327
thanks for the input,
however, there are 5 pins not just one wire...
Old Jul 24, 2003 | 01:23 PM
Scooter29's Avatar
Scooter29
Hmmm. Mine only has two. In and Out. You definately don't want to short something out. Check the wiring diagram in your manual and see what wire leads to the NSS. If you don't have a manual, head down to the library and check out one of them. You can make a couple of copies while you're there. One wire may be for the Slave Cyl. Sensor, Tranny Sensor. You should be able to get through it ok. Also check out autozone.com and go to the repair section. That may help also. Talk with you guys later....
discochris
16
May 20, 2017 08:57 AM
madsonp
Nov 16, 2010 05:55 PM
Dskeet6
Sep 14, 2010 10:29 PM
azwafree
Mar 13, 2005 01:28 PM
rick
Feb 23, 2000 10:43 PM
