Neutral Safety Switch
Old May 8, 2015 | 01:25 PM
79Ford-4x4's Avatar
79Ford-4x4
Neutral safety switch
Need some assistance, I am restoring a 1979 (manual truck) Ford F150 4x4, utilizing a 1978 (automatic truck) wring harness. Originally the truck had a 4 speed granny gear transmision, I have changed it to a C6 automatic. Where does the wiring harness on the neutral safety switch (4 pronge harness) hook to the truck harness?
Old May 8, 2015 | 02:05 PM
herbiemin's Avatar
herbiemin
On my 78 it runs up alongside the transmission and comes up the firewall. the plug is located right behind and kind of above the valve cover on the passenger side. I can try to grab a pic later
Old May 11, 2015 | 08:13 AM
79Ford-4x4's Avatar
79Ford-4x4
Thanks for the info a pics would be great.
Old May 11, 2015 | 08:25 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1978/79 F100/350: Make sure you have the correct NSS .. C6 is different than C4.
Old May 13, 2015 | 08:24 PM
herbiemin's Avatar
herbiemin
Passenger side firewall right above heater hoses
here is a couple pics sorry for the delay. connection is the grey 4 pin connector. if you need more pics I can try to get more.
Old Oct 22, 2019 | 08:40 PM
Josh Ross's Avatar
Josh Ross
Diverdude
I’m partially restoring a ‘78 F100 and had this exact same question. Thanks! I was looking in the wrong spot.
blackgate99
Jun 17, 2016 05:00 PM
highguy2012
May 2, 2012 11:51 PM
F250GH
Jan 25, 2009 09:08 PM
1978fordf250
Aug 15, 2008 03:38 PM
0351mike
Sep 22, 2006 11:01 PM
