1994 f150 speedometer problems
Old Oct 7, 2005 | 07:49 PM
redneck4242002's Avatar
redneck4242002
my speedometer has been going crazy latly and ive bin wonderin wat the problem is with it. help please.
Old Oct 7, 2005 | 08:08 PM
vman's Avatar
vman
What do you mean by crazy? It reads off the speed sensor in the rear differential.It controls the antilock brakes too. Might want to check the wiring and maybe pull out the sensor and check it.
Old Oct 7, 2005 | 08:12 PM
andym's Avatar
andym
The sensor can be pulled out and wiped off with a rag. 95% of the time it fixes the problem.
Old Oct 9, 2005 | 06:57 PM
redneck4242002
thanks ill try it
by crazy the speedometer starts flyin all over the place and thengoes to zero then back up and then all over the place again.
Old Oct 11, 2005 | 08:58 AM
alz's Avatar
alz
If cleaning it doesn't help. Use the search function here and look up "bad PSOM". My speedo still jumps around a little even though the sensor is good and the speedo(PSOM) checks out good too. I believe the tone ring may be bent a little or have a low tooth. When I have to rebuild the rearend, I'll have to fix that too.
Old Oct 11, 2005 | 07:46 PM
canadian 94 ford's Avatar
canadian 94 ford
check the wiring coming off the abs sensor
50trucking
Sep 23, 2014 03:13 PM
howardsamycia
Mar 1, 2014 12:20 PM
Tom2003
Aug 11, 2013 11:48 AM
rashanny
24
Mar 31, 2011 11:14 PM
firstonraceday
Oct 12, 2005 10:15 AM
