Erratic Speedometer
Old Sep 25, 2005 | 05:08 PM
firstonraceday's Avatar
firstonraceday
Erratic Speedometer
Recently my '77 has developed an erratic speedometer needle. I don't hear any type of noise coming from the cable indicating the need for grease however, the old truck is fairly loud so the problem may be that I can't hear any noise.
That aside, I was wondering if the erratic operation may be indicative of:
1. Speedometer cable needing lube
2. Speedometer cable needing to be replaced
3. Problem with the speedometer head/gear
Thanks in advance.
Old Sep 25, 2005 | 05:12 PM
Torque1st's Avatar
Torque1st
Posting Legend
Any and all of the above. Try the lube first. When the cable starts making noise it is often too late and replacement is required.
Old Sep 25, 2005 | 08:29 PM
toddn78's Avatar
toddn78
Its probably the gears. Thats what i had to change when mine was jumping all around.
Old Sep 26, 2005 | 06:45 AM
redneckn17's Avatar
redneckn17
What does it do when it gets erratic?On mine when i really speed up it will go up to 30mph or so then stop then jump to 40 or 50
Old Sep 26, 2005 | 08:17 AM
cigarxtc's Avatar
cigarxtc
heheheheehehe...I kinda gave up on mine. When I bought the truck it was spot on and worked great, but there was a hole burned into the speedo cable from the exhaust. So I replaced the cable with a new one and now occasionally the needle jumps all over the place or pegs out on it's own. Now I use the aftermarket tachometer to gauge my correct speed. I don't hear noise coming from my dash gauges either. Though I was wondering if some type of oil or lubricant on the gears would help or hurt?
Heya toddn78, was it gears in the dash panel that you changed out? Was it replaced with new pieces from the auto parts store? If so, how much did that cost?
Old Oct 12, 2005 | 06:11 AM
mike0's Avatar
mike0
I have the same problem on both ny '75 E250 van as well as my 77 F150 2WD - I've lubed speedo cables on my motorcycles by simply removing the drive from the front wehhel, sliding out the core and oiling it brefore reinstalling
How do you lube a speedo cable on a truck when the core wont just slide out?
thanx!
Old Oct 12, 2005 | 08:35 AM
77460f150's Avatar
77460f150
Make sure the cable is plugged all the way into the speedometer. I had this trouble and found it was the cable was not installed completely at the back of the speedometer, it appeared to be fully inserted but it was not. -Ed
Old Oct 12, 2005 | 10:15 AM
plowpusher's Avatar
plowpusher
like torque said lube the cable just fanagle your hand in behind the dash pop the cable and lube it, maybe you'll have to pull the insturment cluster but that only take 15 minutes it's simple and usually the problem then if thyat doesn't work start looking for other things
I have gone so far as to shoot carb spray from the top till it runs out the bottom end to clean the hoiusing the lubed the cable remember you got 30+ years on these trucks
ITDave
2004 - 2008 F150
Aug 27, 2018 07:25 PM
Snacky
Mar 17, 2015 12:55 PM
50trucking
Sep 23, 2014 03:13 PM
JacobRM
19
Jun 3, 2014 06:35 PM
