E250 2003 speedometer problem
Most likely your cluster has failed and the easiest fix would be complete replacement. These are very year specific; if you go this route make sure you use cluster intended for your year and engine. Here's a good one: http://www.ebay.com/itm/2003-FORD-E250-VAN-79005-MILES-SPEEDOMETER-INSTRUMENT-CLUSTER-GAUGES-2604969-/271246779845?pt=Motors_Car_Truck_Parts_Accessories&fits=Year%3A2003%7CModel%3AE-250&hash=item3f279165c5&vxp=mtre
If you're more adventurous here's a post I made about the pre-digital clusters, it would help you maybe replace just the speedometer portion if you're so inclined: https://www.ford-trucks.com/forums/1...l#post11747876
Hope this helps!
Most likely your cluster has failed and the easiest fix would be complete replacement. These are very year specific; if you go this route make sure you use cluster intended for your year and engine. Here's a good one: eBay]2003 Ford E250 Van 79005 Miles Speedometer Instrument Cluster Gauges 2604969 | eBay
Hope this helps!
Appreciate your help thanks Tom
