What makes trans so hard to pull?
Old Oct 7, 2005 | 06:28 PM
onebluemcm's Avatar
onebluemcm
I've read that pulling the trans on a 4x4 truck is a real pain, hard job. Wondering how come? Thinking about buying a local 92 F-150 - say it has trans trouble, have yet to figure out what he means by that - ANYWAY..... I've had trannies out of other rear wheel drive vehicles but never a 4x4. Just hoping for some idea of waht to expect to get into to pull the trans. Thanks
Old Oct 8, 2005 | 02:59 AM
ford390gashog's Avatar
ford390gashog
the t case is in the way.
Old Oct 8, 2005 | 07:08 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Oct 9, 2005 | 01:14 AM
ivanribic's Avatar
ivanribic
Which means you get to drop TWO driveshafts and typically 1 crossmember, remove and t-case shifters and drop it out and THEN you get to play with the tranny. Once you go through it one time and get it all figured out it's not bad but it can be very time consuming. One big advantage you'll have is the t-case is aluminum and light so it's fairly easy to pull out and put back in place as compared to the old 203's or 205's that weigh 150-180.
Old Oct 9, 2005 | 06:30 AM
onebluemcm's Avatar
onebluemcm
that's what I figured - front and rear drive shaft, then pull t-case from trans, then trans from engine. I have never pulled a t/case from a trans - how are the drive shafts conected? And can the t-case get really frozen to the trans making it hard to get loose?
I had heard you have to gut the interior - well, remove the seat(s) and carpet/mat because there is some sort of steel plate on the floor that has to come loose - any truth to this?
Thanks again all
Old Oct 10, 2005 | 09:00 PM
tcannon's Avatar
tcannon
it will also depend on if it's a married or divorced t-case. and the T_CASE is heavy.
Old Oct 10, 2005 | 09:19 PM
onebluemcm's Avatar
onebluemcm
married or divorced - sorry, I feel like I should know what that means. Integral with the trans or separate entity?
Old Oct 11, 2005 | 06:04 PM
Silent Bob's Avatar
Silent Bob
Just had the fun of doing this recently myself...
You do have to pull up the carpet/floor mat to get to some of the bolts.
The transfer case on a 92 is not that heavy, the transmission is.
An extra body is very helpful.
A transmission jack is worth its weight in gold.
Read the manual. When it says "remove exhaust system", believe it. Even though it doesn't look like its in the way.
Take your time and be methodical.
It's not that difficult, but it's not exactly what I'd call fun either.
Good Luck
Old Oct 11, 2005 | 07:12 PM
serving_time's Avatar
serving_time
a married t case is bloted to the tranny. A divorced is seperate - they are connected by a shaft.
RolnCl
57
Jan 24, 2012 09:51 AM
glovemeister
37
Jul 17, 2011 11:51 AM
cordoba1979
2004 - 2008 F150
Jun 14, 2008 03:52 PM
m14dan
May 6, 2007 07:50 AM
weatherl
28
Apr 24, 2006 04:51 PM
