tran temp
Old Apr 22, 2006 | 01:07 PM
weatherl's Avatar
weatherl
tran temp
I need some advice on tran temp . I am leaving Phoenix on the way to Co. The pull from phoenix to Flagstaff is long and steep. My concern is what trany temp I can be safe with for a long hard pull of approx. an hour long.I am pulling a 5th that about maxes out the GVWR. FTE is agreat place for info.
03 PSD 2X4
4" ex
Superchip set at safe tow
EGT Boost & tran temp guage
HXP
6637 air
MAP mod
Old Apr 22, 2006 | 01:11 PM
aklim's Avatar
aklim
No EGT gauge?
I would say under 180 would be excellent. Wouldnt let it go over 210 or something like that.
Old Apr 22, 2006 | 01:26 PM
CAT_man_963's Avatar
CAT_man_963
This is a thing where some have a lot higher #'s for max temps... but I'd agree with Aklim - I wouldn't let my rig get over 210*... Keep an eye on your temps and if you have trouble - I'd suggest looking into an aftermarket tranny cooler!!
I had to let off on a couple long uphill pulls last year on the way to the Adirondacks for vacation (towing about 8000lbs) - and that really sucks! On a roll - haulin right along with EGT's at like 1100* - but having to get out of it because of tranny temps!! I hope to have solved the problem with my new TruCool, and other tranny mods!
Old Apr 22, 2006 | 01:27 PM
CAT_man_963
Oops - sorry double post - silly "server too busy"
Old Apr 22, 2006 | 03:31 PM
aklim's Avatar
aklim
Psssst. 6.0 Tranny Cooler, anyone?
Old Apr 22, 2006 | 08:16 PM
mjm7920's Avatar
mjm7920
Unless you’re running synthetic fluid, 210 is a good number to stay under. The 10k-11k I pull (live in NV, but pull steep grades in So Cal, UT, around Laughlin, etc.) used to get the tranny hot, but I switched to synthetic fluid and added the deeper (stronger) pan too – now rarely climbs above 200 pulling even in the summer heat. I do plan to add another cooler (with its own fan) – if I keep my 2000 7.3 extended cab as the kids are growing and I may need to go to the crew cab.
Old Apr 22, 2006 | 08:45 PM
Muktown's Avatar
Muktown
this info is from www.dieselsite.com
Millions of automatic transmissions fail every year from overheating.
If you tow a boat, trailer, camper or drive in Stop & Go traffic you risk overheating your transmission fluid.
  • Transmission coolers help extend the life of your transmission fluid and can prevent transmission failure from overheating.
  • When your transmission fluid reaches 200? it starts breaking down.
  • At 240 � varnishes form and transmission life expectancy is cut in half.
  • At 260 � the transmissions internal seals and rubber parts harden and major damage starts.
  • Above 295 � you transmission start slipping, clutches burn out and carbon forms.
  • With each 20 � drop in operating temperature, your fluid and equipment life doubles.
  • Installing a cooler before damage starts and by reducing the transmission fluid temperature by as much as 60 � can greatly extend the life of your transmission.
  • Installing a transmission cooler can prevent transmission burnout.
Old Apr 22, 2006 | 09:06 PM
aklim's Avatar
aklim
How is the fluid affected at those temps if it is say synthetic?
Old Apr 23, 2006 | 07:52 AM
johnny8's Avatar
johnny8
as far as i know... syn has 2 main advantages... it flows better when cold and it can withstand more heat before it starts to break down... i think it also helps these transmisions work better, but that is pure speculation on my part, i have no proof to offer to back that up... i still think an addtional cooler is a MUST on these mules... the only proven way to help your tranny last longer is to keep the temps down... fortunately for me, i know my truck only did light duty before i put the tranny cooler on it, so i have high hopes this tranny will last... i just passed 100k and it's doing great so far...
Old Apr 23, 2006 | 09:18 AM
aklim's Avatar
aklim
I guess my question is whether the hard parts will wear out faster even if the fluid holds up in heat better without breaking down.
Old Apr 23, 2006 | 09:48 AM
Kwikkordead's Avatar
Kwikkordead
What I'm reading from that description is the clutches and seals are the parts that fail when really hot. The fluid breaks down as well but with fried seals, you won't be able to generate any hydraulic pressure to move the truck. Get that cooler installed BEFORE you go and then no worries.
Old Apr 23, 2006 | 10:41 AM
aklim's Avatar
aklim
I guess that synthetic fluid will hold up better. So, the question is at what temp will the trans start to lose mileage. I beileve a lot of the charts start with above a certain number but are they taking the advantages of syn into account?
I didn't want to play with the larger cooler so I went gonzo and installed the 6.0 cooler.
Old Apr 23, 2006 | 11:17 AM
johnny8's Avatar
johnny8
i would say... imo... with syn fluid... i would keep the temps below 250 to be reasonably safe... with the cooler i have, i have not seen any temps above 190... if i saw the tranny getting over 200 i would back off and let her cool down, but that's just me... i almost NEVER see temps above 180... i would say with the 6.0 cooler you have, just watch close when towing and you should be fine... you'll be glad you put that cooler on if you are ever towing something big on a hot day...
Old Apr 23, 2006 | 02:14 PM
aklim's Avatar
aklim
Reason I ask is dad is hauling a trailer that is for ATVs and is about 30 feet long. Also he has a camper on the back and has synthetic fluid (Amsoil). He has a 99 F350 PSD. While he has 80K on the clock and the tranny is ok, he has no temp gauge and won't know where the temp is. He feels that if the tranny hasn't broken, it is ok.All he has is the deep pan.
Old Apr 23, 2006 | 02:52 PM
Kajtek1's Avatar
Kajtek1
Somebody is giving lot of BS here.
Standard ATF is safe up to 250 F on pulling and up to 325 F on braking.
In my motorhome I see 250 F most of the time and few seconds on retarder gets it quickly above 300 F.
You might say it will not last for long this way? My motorhome with 8V71 Detroit is 33 years old. Try again.
