Need help in Axle identification
Old Oct 11, 2005 | 03:06 PM
nsaikia's Avatar
nsaikia
I have a 1979 Ford F100. How do I know what kind of Axle I have? Also, what is meant by splined axle?
Thanks,
Nayan.
Old Oct 11, 2005 | 03:13 PM
andym's Avatar
andym
Front will be a Dana 44, if it's a 4x4, and the rear is probably a 9". I've seen Dana 44's in the rear on late 70's trucks, too. Best bet is to describe the axle. Is there an access cover on the rear with a fill plug about halfway up? Or is it solid looking from the back?
Old Oct 11, 2005 | 07:19 PM
serving_time's Avatar
serving_time
Look at the vehicle tag on the door jam and post the axle code. along with a description. Someone should be able to help. I may be wrong, but I think all F100's came with a 9" rear alxe. The 2 axle shafts engage into gears in the differential. They are splined on the end, as are the gears where they engage. If you need to change an axle shaft for some reason, be careful because the # of splines can be different on 2 different shafts.
Old Oct 11, 2005 | 07:48 PM
nsaikia's Avatar
nsaikia
My axle code is 06, which somebody in this forum deciphered as 2.75 gear ratio. I am trying to price a 3.55 or 3.73 gear ratio. I think my axle is 9", but I will post back with how the back of the pumpkin looks like.
What all is involved when going lower on gear ratio like I want to?
joewaldner
Offroad & 4x4
40
Jul 1, 2008 10:36 PM
blackjack8900
1997 - 2003 F150
Apr 26, 2006 08:49 PM
78bronco
Jul 21, 2002 06:38 PM
proeliator
Offroad & 4x4
Aug 27, 2001 10:41 AM
kenhd
1997 - 2003 F150
Aug 4, 2001 08:55 AM
