leaking windshield...
Old Oct 4, 2005 | 11:01 AM
dorkpunch's Avatar
dorkpunch
so when it rains i get this puddle of water by the drivers side door. Appears to be coming from the rubber seal around the windshield, at the bottom left hand corner. Any way to fix this? Need a whole new rubber seal?
Old Oct 4, 2005 | 12:11 PM
qman's Avatar
qman
You can try to do what the windshield guys do. They use something I think is called butyl. I don't know where you'd get the caulking tubes but they just caulk it in there. I bought a new windshield a few years back and when it leaked all they did was caulk that stuff in there until they sealed out the leak. Took them 3 tries.
Old Oct 4, 2005 | 02:41 PM
4Cammer72's Avatar
4Cammer72
there's no way to really tell where the leak is on the windhsield. id say replace the seal.
Old Oct 4, 2005 | 03:10 PM
qman's Avatar
qman
4Cammer is right. I replaced my windshield with one from a salvage yard. The seal was better than the one in mine so I used it. But to be honest, doing that windshield was a b**ch. I cracked the upper corner on the passenger side.
Old Oct 4, 2005 | 05:08 PM
Nohaj1's Avatar
Nohaj1
I had the same problem with my truck. I bought a replacement seal from JC Whitney and it seems to be working great. Swapping in the new seal really was a pain though.
Old Oct 6, 2005 | 02:50 AM
Steve_Uzi's Avatar
Steve_Uzi
One thing about the Windshield and leaks... This is what the death of my '70 F-100 was... the previous owner had a leaky windshield and so he decided to just use silicon to prevent the water from getting inside the cab... well it did remain outside the cab but it remained in the groove of the rubber seal, so it rotted the whole upper area of my Cab from the inside out...
So if you do wind up pulling your windshield I would recommend cleaning down the entire area and check for any signs of rust.
Old Oct 10, 2005 | 09:22 PM
baitmaster's Avatar
baitmaster
silicone isnt very good about holding water out of anything. thats why they use butyl caulking on your house downspouts. It is much stickier that silicone. You can buy a small tube of windshield caulk, but I dont know what's in it. A new rubber is usually the ticket. use some silicone spray or WD 40 when you install rubber and glass. you know the rope trick right?
Old Nov 10, 2005 | 07:15 PM
Gervis's Avatar
Gervis
if you opt to replace your winshield, just look for a reliable dealer that won't charge you lots of $$$.
Old Nov 11, 2005 | 05:28 AM
jowilker's Avatar
jowilker
The windshield gasket is a dry fit gasket. While adding caulk can change one concern, your system was not designed to be used with it.
It may be time for a new gasket. IMHO
John
schoo
Jul 19, 2013 04:35 PM
BigBlueCat
Sep 23, 2012 06:27 PM
BlueovalFE
1947 and Older Ford Trucks
15
Aug 13, 2012 10:10 PM
F1 48 Ford
Dec 19, 2009 03:13 PM
armstrongfordtrucks
May 6, 2007 11:56 AM
