Jr.'s progress thread
Old Oct 30, 2005 | 09:45 PM
  #61
HappyJack's Avatar
HappyJack
Originally Posted by fordborn
Thats good Clint, it should be ready to roll by thanksgiving then right?
Not unless the welding fairly shows up and does a lot of welding.(shock mounts F&R, cross member, drivers side floor, rear spring pads on 9") Then shocks need to magically appear. And the exhaust needs to jump on the truck fabbing it's self. Then driveshafts need to be done ($$$$$$). And the fender cutting god needs to smile on "Jr.". Course the Doubler needs to be cheaned and the shift lever changed.(John says he can do that maybe sometime next month) Hole cut in the floor for the t-case shifter (stock t-case shifter will only shift the Doubler). Then that will have to have a cover plate and shift boot fabed. Carpet and seats re-installed. Gears for the front. Detroit and gears installed in the spare third member and installed in the front. 44 outers put on the 35 TTB. Rear Detriot Locker needs to show up and install itself in the rear axle. And about 1500 other things I can't remember.
Old Oct 30, 2005 | 09:49 PM
  #62
fordborn's Avatar
fordborn
Shesh, couldn't you have just said "probably not"?
Old Oct 30, 2005 | 09:50 PM
  #63
97Centurion's Avatar
97Centurion
Rub my Belly
What do you mean "I"? Thought you said Sawzall, Jigsaw and Mr. Drill did yours.
uummm yeah that's it. aaahh This is Sawzall typing. uummm Tony is out relieving himself on an OT marker. Yeah, That's it.
Old Oct 30, 2005 | 09:51 PM
  #64
HappyJack's Avatar
HappyJack
Originally Posted by 97Centurion
Wish they made them in some plain black flexible rubber. They are really nice looking though. Looks like I cut out way more than they did on the rear. Bout the same on the front.
What do you have on your truck? Thought it was the same as Clint has on Mad Max...the plain black flexible rubber. Thought I'd see about using the Bushwacker instructions and the roll of flare stuff we used on Mad Max. If I can still find the stuff.
Old Oct 30, 2005 | 09:52 PM
  #65
fordborn's Avatar
fordborn
Thats what I am gonna try. I ordered the same stuff Tony used and am going to try and follow the bushwacker instructions.
Old Oct 30, 2005 | 09:55 PM
  #66
HappyJack's Avatar
HappyJack
Uh...........yep!
Old Oct 30, 2005 | 09:56 PM
  #67
HappyJack's Avatar
HappyJack
Where are you getting it at?
Old Oct 30, 2005 | 09:58 PM
  #68
97Centurion
Rub my Belly
Jack yes but I'd like to see some made like the Bushwacker flairs in the flexible stuff. I like that style better.
Sound's like we need to have a fender cutting party. Anyone have a nice toasty warm shop that will hold several BII's?
  #69
fordborn's Avatar
fordborn
JCW item # WK141414
Old Oct 30, 2005 | 10:00 PM
  #70
fordborn's Avatar
fordborn
I think Marks will hold 3.
  #71
HappyJack's Avatar
HappyJack
I though I bought the stuff we used on Mad Max at Whitney's. Thanks.
Old Dec 6, 2005 | 11:53 PM
  #72
HappyJack's Avatar
HappyJack
Well picked up the doubler today. It now has the correct shift lever and was cleaned and check out. Just need to trim the rear adapter plate and hope it will all fit. May have to install a body lift or mod the floor pan to get it in. Or should I say to get the t-case on the back of the doubler. time
Old Dec 7, 2005 | 12:01 AM
  #73
fordborn's Avatar
fordborn
Cool Jack, I will be real interested in coming down and seeing the doubler. Have seen the picts but that is not the same.
Old Dec 7, 2005 | 12:36 AM
  #74
HappyJack's Avatar
HappyJack
If you'd like I'll try and get Clint to hold off till you can get down. Your even welcome to come down a watch the install.
Old Dec 7, 2005 | 07:03 AM
  #75
fordborn's Avatar
fordborn
no no don't hold up installation. I am just as interested in seeing how it all ties into place.
