When you had a crossflow Fuel Tank Problem did you ever Check your Fuel Pressure!!!
1.My rear tank fills my front tank, i have a 1994F150 duel tank 5.0 automatic
and
2. I have correct fuel pressure when truck is running with and without vac. line off or on FPR, but as soon as you shut the motor off it goes to zero in 1-2seconds
(i know FPR is good and the injectors are good)
3. I was just curious if anyone else had a fuel pressure problem along with a bad checkvalve, or checked there fuel pressure drop off rate when they had this condition
4. I searched this forum for two hours and know one else complained a bout a fuel pressure problem when they had there crossflow problem, they all acted like there truck always ran fine during all stages of driving. Does a bad Check Valve cause Fuel Pressure Problems
5. I think I have a bad check valve and weak fuel pump condition at the samt time, my truck bucks and falls on its face when cruising down highway when trying to give it a little gas, and when i take off from a stop light, but the truck runs fine when i give it 3/4 or full throttle.
I will being replace my front pump soon enough but I am just curious if in the end will it fix my fuel pressure problem to,
Let me know your experiences guys
Thanks Nate
and
Thanks Nate
My front tank fills my rear tank. Very common for one to fill the other on dual tank trucks. Even after the recall that replaced check valves. Also had a fuel pump replaced. I just make sure there is room for fuel in my back tank when using the front. There are tons of threads in this forum on the duel tank issues. Gary
I was just getting ready to post a question on this. My friend has a 93 150 w/dual tanks. The when feeding off the aft tank the return must be going into the front tank, because it will over fill. Where are the check valves that you speak of? Also, at times when the truck is running off the aft tank it runs as if it has bad gas. Could the check valve for the front tank be hung open and dropping the fuel pressue and causing this condition? Steve
87-91 have check valve on frame rail next to fuel tanks, 92-96 have check valve inside of the tank, it is part of the fuel pump assembly (FDM) (Fuel Delivery Module)
unless you know how to get around it, you have to replace the whole fule pump assembly, this is how the Auto Parts Stores sell it, i think you can just buy the pump from NAPA but, its worth the extra $50 to just replace the whole assembly
the recall is only good up to 12years or 150,000 miles from the build date of the truck
i am out of luck because mine is 94 with 162,000miles on it.
I think i have a weak pump along with my fuel pressure issue, thats why my truck runs like it does, (I hope replacing the front fuel pump is enough to fix it)
Nate
Nate
on my truck if you push the pin down on the schradervalve, hardly nothing comes out, its like a little volcano spilling down the sides, it will not shoot anything out. also with fuel pressure tester hooked up engine off with fuel pump grounded making 40-42psi,(it takes a couple of seconds to get up to that) i push the pressure release button on fuel pressure tester and it comes out very slow out the line like a leaking faucet,
i have done this on my 5.0 Mustangs and it comes out with some force, i even have to watch the line because it could spray fuel everywhere and come out of the container i have the line going to.
I am pretty sure the fuel pump is weak to.
I bought the new front tank pump last night and will install it in the next couple of days.
Hopefully this will solve my problem
Nate
Nate
kirkharrod
12-10-2011 06:14 PM
oreodog
07-04-2011 11:01 AM
driptorch970
15
05-11-2009 12:30 AM
