1995 f150 4.9 low fuel pressure in 1 tank
I replaced my rear fuel pump about a year ago. Now the truck runs poorly on the front tank. when switching to front tank it clears up. My question is after checking fuel pressure on the rear i have 32psi and it does not go up when you pull off the pressure regulator hose. the front tank reads 47psi and goes up when you pull off the fpr hose. Can my new pump be bad already? Or does the front pump have a bad check valve? thanks
33homerdoodle
01-17-2016 04:00 PM
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
03-22-2015 04:55 PM
bigblockford_390
07-18-2011 07:00 AM
predaina
29
03-29-2011 07:07 PM
