ignition switch assembly.
Old Sep 23, 2005 | 04:03 PM
hungrymonkey's Avatar
hungrymonkey
before we start, 66 F100, swb, with 302, auto. custom cab...
I got a key made for my truck, and I went to use it to start it. But the ignition switch is apart.
The black plastic piece that the wiring harness went into has seperated from the metal housing that holds the tumbler.
as of right now I have a black plastic disk that fits into a copper looking disk. That in turn goes onto the black plastic piece that has the wiring harness.
My problem is that the spring on the plastic disk keeps popping out, which binds up.
Also the black plastic piece that the loom goes into wll not stay attached to the metal housing. It is not secured in any way. What is the best way to resecure it?
Old Sep 23, 2005 | 05:43 PM
barry's Avatar
barry
You need a new switch. The key and tumbler part can be re-used. If you put the old one back together, it's just going to come apart again. probably at the worst possible time. Just get a new one and be done with it.
Barry
Old Sep 23, 2005 | 05:52 PM
hungrymonkey
Is that something that could be sourced through a local shop, or a specialty dealer?
Old Sep 23, 2005 | 05:57 PM
barry's Avatar
barry
Try your local NAPA store, or any GOOD auto parts store. If not, I can look up a part number for you and see if there's any NOS Ford ones out there.
Barry
Old Sep 23, 2005 | 06:13 PM
hungrymonkey
called napa. They had it. I was a bit suprised.
thanks for the help.
Old Sep 23, 2005 | 08:15 PM
hungrymonkey
now reinstalling is giving me fits.
I dont know who had the bright Idea of making the bolt in the back of the switch pointy. Thats just wrong.
Old Dec 21, 2005 | 07:58 PM
amoafin's Avatar
amoafin
ignition switch wiring
I just purchased my 1966 F-100 LB at an auction. Does anyone know what wires are which in order to attach the ignition switch? I found that the ignition switch was wired incorrectly. I don't know which wire is the "On" wire. I shorted the red and yellow together and got the engine to crank up but as soon as I openned the connection, the engine stopped. Please help me. I'm new.
Old Dec 22, 2005 | 06:08 AM
jowilker's Avatar
jowilker
amoafin, Welcome to FTE My #1 Choice!
Hopefully one of our readers will be along shortly with his manual handy and can give you the correct answer.
John
Old Dec 22, 2005 | 11:43 AM
Redmanbob's Avatar
Redmanbob
I have no business answering this as I only tinker with boat engines. But it's usually green or black/green that is the run wire. yellow and green then touch red to start. But I'm not going to tell you to do it. wait for someone more knowledgeable on this..
Old Dec 22, 2005 | 11:49 AM
Redmanbob's Avatar
Redmanbob
I found this handy when I first got here from some help on the forum..www.tocmp.com/tOCMP/wiring/1964F100/index.htm
Old Dec 22, 2005 | 07:50 PM
amoafin's Avatar
amoafin
Thanks! That helped a whole lot.
afonda
Mar 27, 2024 11:04 AM
Sunline Fan
Aug 23, 2022 06:13 AM
GreenMM
WTB - Ford Trucks & other vehicles
Feb 9, 2017 12:09 PM
jyro
Jan 27, 2017 08:08 PM
ky_que
1983 - 2012 Ranger & B-Series
17
Jul 2, 2004 10:39 AM
