I have 4 settings of head lights depending on how i hit the dimmer switch,
high beam
low beam
off
partial highbeam
its weird if I dont hit the switch just right to dim my highbeams my lights will either go out all together or go to a step inbetween high and low beam.
my question is where are the headlights switched? are they switched in the floor mounted high beam switch or is there a relay under dash or something, my guess is the floor dimmer switch is faulty and needs replacing but i thought id run it accross the forum.
The switch carries all of the current. See the tech paper here on converting to relays if you are interested. It is a worthwhile upgrade on our trucks.
I will look thanks,
when the lights are in high beam are both low and high beam fillaments on???
when the lights are in high beam are both low and high beam fillaments on??? -gbm-
-No, but you could wire relays up to do that. Just have the output from the high beam relay trigger the low beam relay thru a diode. The increased heat will probably melt your headlight connector tho.
