1978 - 1996 Big Bronco
Freeze Plug Leaking....Advice.
Old Aug 19, 2005 | 12:19 AM
h_sach's Avatar
h_sach
Just my luck, had a new radiator put in my 78 Bronco and now that I have a working cooling system, a freeze plug starts to leak. It is a slow leak on the passenger side out of the plug that is directly under the motor mount. I don't see any way to get to it. Is this a hard job? Do you think an auto mechanic will kill me with labor on this? It looks as if the engine will have to be lifted to even access the plug. Please let me know if there is another way. If the engine does have to be lifted it is probably a good time to have the rear main seal fixed, it has been leaking for quite a while. Thanks for any help with this.
Old Aug 19, 2005 | 06:53 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 19, 2005 | 08:02 AM
holland501's Avatar
holland501
Trying to replace a freeze plug with the engine in the truck is going to be very difficult. I won't say it can't be done but if it were me, I would opt for an expansion style plug. This is a rubber plug that you expand by tightening a bolt in the center of the plug. If you had a thermos bottle in your lunch box as a kid(ya, I'm that old)it works the same way. Measure the hole and go to the parts store and ask for an expansion plug. When you see it, it will be self-explanatory how it works. Now getting the old one out will be your only problem. Good luck.
Old Aug 19, 2005 | 11:07 AM
McLeod's Avatar
McLeod
If you don't already have a block heater, now might be a good time to install one. They go in the block in place of the freeze plug.
Old Aug 19, 2005 | 11:51 AM
qman's Avatar
qman
I've replaced a couple of them. I can't recall having a problem with access but I do know there wasn't much room and they are a pain in the butt. The way to get them out is to put a screwdriver up in the lip of the cup and tap it with a hammer. You'll twist the plug such that half is in the block and the other half is sticking out. Then you just pull it out. Then you just tap a new one into the same hole. I just did one on my 72 F100 about 3 mos ago.
Old Aug 19, 2005 | 01:25 PM
poffutt's Avatar
poffutt
I havent had to ever change a freeze plug, but I have had to lift a 351 engine to change the oil pan gasket and it is not as hard as you would expect. Just remove your fan shroud unbolt the engine mounts, disconect your exhaust at the y pipe and jack it up.
Old Aug 19, 2005 | 03:13 PM
h_sach's Avatar
h_sach
Would I also have to loosen the tranny mount to lift the engine? Since I would have the engine lifted, would this be a good time to fix the leaking rear-main seal? Thanks.
Old Aug 23, 2005 | 02:57 PM
h_sach's Avatar
h_sach
Just and update. Took it to a local repair shop and they changed out two of my freeze plugs for $187. Not a bad price in my opinion, sure beats me laying under the Bronco breaking more stuff than I fix. They also confirmed that my rear main seal is leaking, they said they would fix it for around $500. I have to do some thinking on that though. Thanks for all the advice.
Old Aug 23, 2005 | 04:22 PM
fordboy_52's Avatar
fordboy_52
i replaced one awhile back with a couple extentions on my 1/2 ratchet, just made them come into the fender and then hit it with a hammer and i could get it knocked out (well in)
Matt
Old Aug 23, 2005 | 04:23 PM
fordboy_52's Avatar
fordboy_52
dang dude, for $500 ill fix a leaking rear main too... its not that hard
Old Aug 23, 2005 | 04:34 PM
h_sach's Avatar
h_sach
Yah, $500 does seem like a lot but I have grown tired in the last few years of working on my vehicles. I pretty much have all new cars now and I usually don't keep them past their warranty just so I don't have to work on them. Of course I love this Bronco so I will never get rid of it, I just have to accept that I will probably pay someone else to do the bigger jobs. Not a snob or anything, I just don't enjoy it anymore. My wife also prefers that I send it out for work so she doesn't have to hear me swearing from the garage.
Old Aug 23, 2005 | 08:58 PM
jem270's Avatar
jem270
I have had good luck in the past with putting an oil additive in the oil for fixing leaking rear seals.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old Aug 24, 2005 | 02:35 PM
fordboy_52's Avatar
fordboy_52
lucus motor oil addative might fix it
Matt
idiabuse
Aug 17, 2014 11:31 AM
im2tall33
May 9, 2012 04:15 PM
jimjoebob99
Nov 8, 2010 02:17 PM
mlcopen69
Oct 29, 2009 04:34 PM
MDraper
15
Dec 29, 2002 03:54 PM
