REALLY easy CCV mod!
Old Aug 25, 2005 | 05:18 PM
  #31
edub32's Avatar
edub32
About the plumbing the ccv into the exhaust....Could you use a braided steel line for that??? I think the exhaust would get a little hot for that rubber tubing.. The braided steel line would look pretty good too.
EDIT: Hmm, and expensive too. I read about the 1/2 tubing but I really like the flexibility. Alternatives anyone...?
Old Aug 25, 2005 | 05:39 PM
  #32
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
how about a 1' piece of metal tubing welded in on an angle, and then connect that to about 2' of high temp silicone/rubber hose that connects to the regular hose going to the crank case vent nipple?
Old Aug 25, 2005 | 06:16 PM
  #33
Fat Diesel's Avatar
Fat Diesel
I used the copper pipe section because it would dissipate the heat a little bit. I actually "borrowed the idea" from SUBMAN on TDS. I did it the exact same way he did and he's been running it a long time, years and tens of thousands of miles if I recall correctly. Last weekend I pulled some nice grades on Hwy88 and I80 pulling a relatively light trailer with a VW Dune Buggy (Mad Max) and got the EGT's up to about 1200 for some short durations. I can happily report that the heater hose has not melted off the copper pipe. Some people will be able to bring their EGT's a little higher. I think the flow of the relatively cooler CCVMMGWIBII (CrankCaseVentMakeMeGagWhenIBreathItIn) gas helps keep it cool as well, but who knows for sure. It just works.
Here's a better pic showing the e-vac bung kit I got from Jegs, the union, and the pipe.
<TABLE cellSpacing=1 cellPadding=4 width=700 border=0><TBODY><TR><TD bgColor=#bdd8ff></TD></TR></TBODY></TABLE>
Old Aug 25, 2005 | 08:38 PM
  #34
HP junkie's Avatar
HP junkie
I am thinking of getting an oil catch can from Summit Racing. I think it would look better and no smoke. They cost around $29. Only disadvantage is having to empty it.
Old Aug 25, 2005 | 08:49 PM
  #35
johnny8's Avatar
johnny8
ok, dumb question here, but, how does it work... and where do the fumes and the pressure go...?
Old Aug 25, 2005 | 09:18 PM
  #36
HeatStroked's Avatar
HeatStroked
HERE
is a great thread and actual test results comparing the open CCV with the stock, Racor and catch can type units.
Old Aug 26, 2005 | 02:32 AM
  #37
Hello's Avatar
Hello
I got mine going all the way back to the rear bumper. No bad smell. After someone told me at a stoplight, I have an exhaust leak on the rear driver's side, I made a larger diameter plastic extention and spray painted it silver. Then put that silver piece below the driver's side rear bumper so it can be seen, so now it looks like a small exhaust pipe, and not a leak there. If anyone stopped behind me now is not saavy, they may think I have dual exhausts on my diesel!
Old Aug 26, 2005 | 11:30 AM
  #38
444dieselrod's Avatar
444dieselrod
Hello. look at this one.
http://community.webshots.com/photo/...44529926npnHFd
I used to get alot of looks for mine, so I took it off, it just stops under the fuel tank now, soon to go into the exhaust. but it was a cute lil exhaust pipe for awhile.
Diesel Rod
Old Aug 26, 2005 | 12:19 PM
  #39
Hello's Avatar
Hello
Diesel Rod that is cute! If anyone asks why one exhaust is smaller now, I'll just say it's a generator. But in the future I plan to cut a 3 inch diameter plastic bottle, cut the end off , silver paint it and then stick it in the end of the CCV hose to look like a real turned down exhaust pipe. The smoke is most noticeable at night in stop and go traffic. Looking back in the side mirror I can see the smoke swirling illuminated by the car's headlight in back of me, and imagining what that driver is thinking!
PowerstrokeJunkie
Jun 18, 2006 07:28 PM
PowerstrokeJunkie
17
Jun 1, 2006 09:47 PM
PowerstrokeJunkie
18
Feb 22, 2006 10:01 PM
PowerstrokeJunkie
Feb 6, 2006 12:00 PM
PowerstrokeJunkie
13
Dec 15, 2005 09:01 PM
