General Automotive Discussion
Dream engine
Old Aug 22, 2005 | 04:52 PM
  #46
Ford_Six's Avatar
Ford_Six
300-6, different head, maybe cross flow, different pistons and about 14.5:1 compression, HEU injectors firing diesel fuel into it, with a similar hydraulically actuated valve system allowing unlimited variable valve timing and lift, along with compression braking. A dual turbo system producing about 65psi of boost, able to deliver over 400hp and 1100lb/tq. Hook this up to an overdrive automatic with a locking torque converter able to lock in every gear, about a 3.00 rear drive ratio, in a 2wd fairly light truck, maybe about halfway between the F-150 and Ranger. Depending on fuel system tuning and driving habits, this should be more than capable of towing as much as a stock F-250 diesel, while returning 50+mpg empty.
Old Aug 23, 2005 | 01:26 PM
  #47
77300i6's Avatar
77300i6
I would take the 300L6 and do the following:
Increase stroke to 4.125"
DOHC 4 valves / cylinder
Sequential Multi-Port FI
10:1 compression
Turbocharged
This should net an easy 300hp and get decent mileage
Old Aug 23, 2005 | 08:33 PM
  #48
Fordzlla's Avatar
Fordzlla
That ceramic engine thing sounds neat, but I can't help but think it is either a hoax or a very far-fetched idea. I can't see how friction would not be a problem. I don't care how smooth two pieces of material are, rubbing them together at 5000 rpm with a load on them will cause them to heat up and fail. There would have to be some kind of an oil film or something to act as a barrier between all the moving parts.[/QUOTE]
Apparently, thats the neat thing about certain ceramics. They dont absorb heat, or transfer heat. Thats how they are able to turn such a high percentage of the fuel (heat) into motion. I remember learning about ceramic engines 25 years ago when i was in college. I understand that some ceramic parts are beginning to be used in gas turbine applications.
FishOnOne
Jan 9, 2015 06:20 PM
GB SISSON
19
Feb 26, 2014 05:27 PM
bobbytnm
30
Dec 4, 2010 07:13 PM
WildCat01
33
Oct 26, 2010 08:04 PM
65fordguy
Oct 9, 2009 02:43 AM
