Power steering flush
Old Aug 12, 2005 | 08:40 AM
neilc88's Avatar
neilc88
Hello all,
I just completed the ATF flush on my tranny. I have a some extra Mercon ATF left over and wanted to flush the power steering. The manual does not list its capacity, just fill to line. Any idea how many quarts it takes to flush the power steering and the best location to drain the old fluid?
Old Aug 17, 2005 | 12:00 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
Forgive me for my stupidity, but you can use transmission fluid in your power steering?
Old Aug 17, 2005 | 02:42 PM
neilc88's Avatar
neilc88
That's what the manual calls for. I disconnect the line by the cooler for the drain. Refilled 2 quarts to full. Pretty easy to do.
Old Aug 17, 2005 | 03:52 PM
Big Rig's Avatar
Big Rig
Nelic88,
I too have some Mercon left over...I wanted to do this, but I didn't know how to.
Can you explain a lilttle bit better how to do this flush. I have an 02 Ex with the V-10..
Thanks..
Big Rig
Old Aug 17, 2005 | 11:20 PM
AZ EX's Avatar
AZ EX
I used a rubber bulb and attached a piece of hose to it then stuck it into the res. and sucked out the old oil (about a quart) then topped it off with new fluid. I've been doing this every oil change (5K) so the old oil gets dilluted. It looks very clean when I pour it out into the waste container.
FDNY13
Nov 11, 2013 05:55 PM
Enomra
Jul 10, 2012 01:08 PM
1999SuperD
31
Mar 27, 2010 08:53 AM
xplorerboy
Dec 6, 2009 07:48 PM
Redranger03
1983 - 2012 Ranger & B-Series
Oct 1, 2009 03:48 PM
