Power Steering Fluid 2003 Ranger?
I just flushed mine with Dexron III / Mercon. Reading the product site, I believe the Castrol Mercon V product is an acceptable replacement for Mercon.
Castrol USA - MERCON V
Read through this TSB & note any system specifing Type "F" fluid, is to continue using it.
Ford no longer markets or licenses the old "Mercon" recipe & has changed the Motorcraft Mercon-V recipe to make it a multi-vehicle fluid, that can now be used in former "Mercon" applications.
If we choose to use other than Motorcraft, check to be sure it meets Fords new recipe specifications for a multi-vehicle fluid.
07-1-7***MERCON® ATF REPLACED BY MERCON® V AS A SERVICE FLUID FOR SOME POWER STEERING SYSTEMS
dalfollo
1997-2006 Expedition & Navigator
03-13-2004 03:43 PM
