power Steering ATF Flush
Old Mar 20, 2010 | 10:26 AM
1999SuperD's Avatar
1999SuperD
What are the benifits of the doing this flush and to you leave ATF in it?
Old Mar 20, 2010 | 10:28 AM
SGnAZ's Avatar
SGnAZ
New fluid is always good,and Yes,use ATF fluid.
Old Mar 20, 2010 | 10:30 AM
1999SuperD's Avatar
1999SuperD
Ok well i just replaced my pump 2 weeks ago and put power steering fluid in it, should i drain it and put ATF in it? what are the advantages of using ATF?
Old Mar 20, 2010 | 10:34 AM
SGnAZ's Avatar
SGnAZ
Ford Super Duty Power Steering Flush | Superdutypsd.com
Old Mar 20, 2010 | 10:46 AM
1999SuperD's Avatar
1999SuperD
Thanks for that link that is great site.
Old Mar 20, 2010 | 10:56 AM
F350-6's Avatar
F350-6
The pump and your hydroboost system is designed to run on ATF. You need to get the correct fluid in there. Follow the flush procedure link above.
Welcome to FTE
Old Mar 20, 2010 | 10:58 AM
Izzy351's Avatar
Izzy351
I put Mobil1 Syn ATF in mine, and it quieted it down -- I'll bet yours is whining with PS fluid, isn't it?
Old Mar 20, 2010 | 11:09 AM
1999SuperD's Avatar
1999SuperD
Not really. But it is sure hard to turn at a stop. Im not sure if thats normal or not but....Im going to flush it out when I get off work and fill it with ATF. Now I feel like a dumb a$$ for not knowing that it takes ATF and not power steering fluid. Those dang guys at the part store screwed me LOL
Old Mar 20, 2010 | 11:24 AM
Izzy351's Avatar
Izzy351
LOL... I know the feeling. All the fluid requirements are in the owner's manual. The two changes are that they now put 75w-140 in dually rear ends and the front diff, and you can use Mercon V in our transmissions...
Old Mar 20, 2010 | 11:30 AM
clintbonnie's Avatar
clintbonnie
In case you don't have all your owners guides, here is a link to download them....
Ford, Lincoln & Mercury Service Coupons | Save Money on Your Next Service Appointment | FLMowner.com .. Just click on "Glovebox" once you get to the link..
Old Mar 20, 2010 | 11:36 AM
1999SuperD's Avatar
1999SuperD
Thanks guys
Old Mar 20, 2010 | 12:21 PM
1999SuperD's Avatar
1999SuperD
powersteering fluid wont mess up the pump and other conponets will it?
Old Mar 20, 2010 | 02:18 PM
crazer42's Avatar
crazer42
im not sure! if it will ruin anything but putting mobile full synthetic made the world of difference! stopped all whining, and much smoother! easy fix thats for sure
Old Mar 20, 2010 | 02:21 PM
1999SuperD's Avatar
1999SuperD
is your guys trucks hard to steer at a stop?
Old Mar 20, 2010 | 02:29 PM
clintbonnie
No.. ..I second the idea on Mobil 1 mercon ATF synthetic... available at Auto Zone
