Power Window Failure
Old Aug 11, 2005 | 10:33 AM
bob the viking's Avatar
bob the viking
Hey Gang....
The wonderful power window on the driver's side (naturally) has ceased to function. It acted real slow going up the last time (had to help it) and now doesn't work any more. I assume since the amount of times it's been used, the motor has failed. Does anyone have any advise or know of a site that could help me thru this daunting task of replacing the motor? I have a Haynes but, it doesn't have any advise to offer. Thanx in advance... BTV
Old Aug 11, 2005 | 12:44 PM
l-m tech's Avatar
l-m tech
take you door panel off and the dust barrier.where the motor bolts up to the regulator assy,there should be 3 center punch marks in the door skin.drill them out with a 1/2 drill bit and remove the 3 bolts.its easy just make sure you are over the bolts.
Old Aug 11, 2005 | 01:06 PM
andym's Avatar
andym
You don't even need to do that.
Remove the door panel and the dust barrier. Reach inside the door and pop the motor out of the bracket. You can see inside the door how the top of the motor comes out. Then just unplug it. Installation is the reverse. No drilling necessary.
Old Aug 11, 2005 | 02:02 PM
l-m tech's Avatar
l-m tech
how do you pop it out of the bracket.ive got to see this.
Old Aug 11, 2005 | 03:13 PM
bob the viking
Thanx for the advise! I'll be giving that a try here real soon. Just got the exhaust swapped out. Trying to get her inspected......
Old Aug 11, 2005 | 03:34 PM
andym's Avatar
andym
The bracket is C-shaped so that the motor pops out one way. I can't remember if it's up or down. All it needs is some force and it will come right out.
IdrinkPBR
May 4, 2013 11:17 PM
brad2388
1997 - 2003 F150
Aug 6, 2009 12:28 PM
Tipsz
Aerostar
Aug 24, 2004 11:59 PM
ubermich
1978 - 1996 Big Bronco
23
Jun 23, 2004 06:11 PM
baw289
Jan 29, 2004 04:15 PM
