Help with power window issue
Old May 4, 2013 | 01:28 PM
IdrinkPBR's Avatar
IdrinkPBR
My driver side window on my '95 F-150 was working fine, but now it won't go up or down. I can hear the motor working, but the window doesn't move. It's as though the window isn't connected to the motor. Any suggestions?
Old May 4, 2013 | 02:27 PM
jdan1993150's Avatar
jdan1993150
Your regulator is most likely broken or went too far and the gear got disconnected.
Old May 4, 2013 | 03:52 PM
Encho's Avatar
Encho
The Southernmost Mod
You need to take down the motor, you could think of the motor as a two part system, the electrical and the mechanical. Since you can hear it turning, then the failure is in the mechanical part, open the round part of the motor and you'll find some plastic gears, which probably failed and will need to be replaced. I can't remember right now which size, but using some bolts in place of the gears will solve this issue permanently. If you prefer plastic gears then the help section on a hardware store will have them.
Old May 4, 2013 | 04:20 PM
IdrinkPBR's Avatar
IdrinkPBR
Originally Posted by Encho
You need to take down the motor, you could think of the motor as a two part system, the electrical and the mechanical. Since you can hear it turning, then the failure is in the mechanical part, open round part of the motor and you'll find some plastic gears, which probably failed and will need to be replaced. I can't remember right now which size, but using some bolts in place of the gears will solve this issue permanently. If you prefer plastic gears then the help section on a hardware store will have them.
Thanks. I got the motor out and replaced the plastic parts without issue. So, assuming I can remember how to put the motor back in, I should be all set. Thanks again.
Old May 4, 2013 | 11:17 PM
Encho's Avatar
Encho
No problem bud, we're here to help each other.
CClark56
19
Sep 3, 2014 09:46 PM
logger1989
May 5, 2014 08:46 AM
1fordtruckman
Oct 22, 2007 07:44 AM
shadetree mech.
Nov 22, 2005 03:17 PM
buckeyebronco
1978 - 1996 Big Bronco
Apr 16, 2004 12:23 AM
