LiteOn SOHW-1693S drive...
have any of you had any trouble with this drive?
I built a pc for a friend... and for some reason, I can't get this thing to work. It seems as if it's having a problem being compatable with the system. The system is as follows (well, as close as I can remember, I built it back in March):
AMD3200 64-bit processor (which I suspect may be the culprit)
Gigabyte N-force board (I forget exactly which model)
512 DDR400 Kingston
80 Gig. Maxtor hd.
and the SOHW-1693S.
Here's what happens... anytime I put a cd of anykind in it, the pc will lock up (or atleast slow way-down). When I insert a dvd and start the player, it will show about the first 5-10 seconds of the disc (whether that's the previews, opening scene of the movie or the "Paramont" stars... what-ever) then it shuts down the dvd software.
So, I thought... maybe it's a bad drive. I pulled SOHW-1693S (that I know works) out of my system, and swapped it in... same thing. So, I'm thinking this is a 64-bit processor problem... because, I next tried his drive in my pc... works just fine.
My pc:
2500+Barton AMD
Gigabyte MB (not N-force... hmm... forget exactly which chipset it is though)
Maxtor 20G hd.
512MB DDR400 Kingston
Anyways, help would be much appreciated... this thing has been collecting dust in my bedroom for months now.
STan
512 DDR400 Kingston
80 Gig. Maxtor hd.
and the SOHW-1693S.
My pc:
2500+Barton AMD
Maxtor 20G hd.
STan
I believe it is a 64bit version of XP Pro... all I know is that my version of XP Pro wouldn't allow the pc to even run past POST.
Tried the updated drivers... nothing.
The drive is on it's own cable, running master off of what I would assume would be the primary slot. There is a slot 1 (HDD), 2 (DVD) 3/4 (which are further down the board).
The system will run just fine if you don't attempt to run a cd/dvd. Solitare, etc... it all works fine.
STan
STan
CowboyBilly9Mile
12-17-2003 10:54 PM
