Decoding door tag
Old Dec 29, 2015 | 09:06 AM
Binkowski's Avatar
Binkowski
Decoding door tag
Hi all,
I've searched and searched but there doesn't seem to be an easy one stop door tag decoder. I have a new toy for Christmas and am trying to learn more. I've learned a couple things but interested in getting all the info. Can anybody help me out please?
WB 139 kinda self evident
GVW X143
Body J6M assume this is extended cab cause that's what I have...
Trans U
Axle 19 Non posi 3.55
Tape P
Springs L4I
thanks,
Binkowski
Old Dec 29, 2015 | 09:33 AM
Benningtonr's Avatar
Benningtonr
I would like to know more as well about mine, maybe a link or a decoder ring?
I apologized for the highjacking, I have the same questions.
Old Dec 29, 2015 | 09:50 AM
subford's Avatar
subford
The year of the truck along with the VIN without the last four numbers would help out a lot.
The VIN:
By looking at the seventeen-digit VIN number a variety of information about the vehicle can be determined. The first three digits identify the manufacturer and the vehicle make and type. The fourth digit determines the Gross Vehicle Weight Rating (GVWR-Class) and Brake System for Ford completed Trucks and MPV's. For Buses and incompleted vehicles, the fourth digit determines the brake system (only). Digits five, six and seven identify the model or line, series, chassis, and cab or body type. The eighth digit points out the particular engine found in the vehicle. Digit nine is the VIN check digit. The tenth digit identifies the model year of a Ford-completed vehicle, or the model year of the incomplete vehicle, if sold by Ford as an incomplete vehicle. The eleventh digit determines the assembly plant. Digits twelve through seventeen make up the sequence serial and warranty number. Digit twelve uses the letter A until the production or sequence of 99,999 units (digits thirteen through seventeen) is reached. Letter A then becomes B for the next production sequence of vehicles.
Vehicle Data
The Vehicle Data appears on the Safety Compliance Certification Label on the second and third lines following the identification number. The code set (two numbers or a number and letter) above COLOR identify the exterior paint color (two sets of codes designate a two-tone). The three digits under WB designate the wheelbase in inches. The letter and three digits under TYPE/GVWR designate the truck model within a series and the gross vehicle weight rating. The letters and/or numeral under BODY designate the interior trim, seat and body type. The transmission installed in the vehicle is identified under TRANS by an alphabetical code. A letter and a number or two numbers under AXLE identify the rear axle ratio (when required, a letter is also stamped or number after the rear axle code to identify the front axle). The letters and/or numerals under TAPE designate the external bodyside tape stripe. The spring usage codes for the vehicle is identified under SPRING.
A two-digit number is stamped above DSO to identify the district which ordered the vehicle. If the vehicle is built to special order (Domestic Special Order, Foreign Special Order, Limited Production Option or other special order), the complete order number will also appear above DSO. The following charts list the various vehicle data codes.
Old Dec 29, 2015 | 10:04 AM
Conanski's Avatar
Conanski
Don't you guys no how to use dat dere interwebs search ting...
Ford Door Sticker Decoder - Ford-Trucks.com
Old Dec 29, 2015 | 10:29 AM
rla2005's Avatar
rla2005
Way too funny
Old Dec 29, 2015 | 10:31 AM
Benningtonr
It does not show my axle code H7 i have seen it from a LS3.31 to a LS 2.43
Old Dec 29, 2015 | 10:44 AM
Binkowski's Avatar
Binkowski
Thanks
Thanks Conanski.
Yes, I do know how to use the search but it is very picky so by me using door tag instead of door sticker it didn't give me that link. The search within the forum is strange and most times you get so many hits its difficult to find what you are actually looking for.
But thank you. Sometimes I end up with more questions than I had to start with...
Old Dec 29, 2015 | 10:53 AM
Conanski's Avatar
Conanski
None of these charts and tools are complete, it doesn't have E series axle codes either.
Here's a chart with H7 in it...
Ford Axle Code Chart - Ford-Trucks.com
Old Dec 29, 2015 | 10:55 AM
Benningtonr
Great thank you
Old Dec 29, 2015 | 11:46 AM
Binkowski's Avatar
Binkowski
more info
Ok, after searching and searching I found this to be the most helpful link:
FordEtis home page
Enter your VIN and then...
Make sure you click on the
There are more minor features for this vehicle, click to expand this list.
And you will get a lot more info.
Old Dec 29, 2015 | 12:09 PM
Benningtonr
Awesome find, thank you
Old Feb 22, 2024 | 06:48 PM
Michael Pinkerton's Avatar
Michael Pinkerton
1st Gear
That one is to old, is there a decoder for newer trucks? I couldnt find one.
Old Feb 23, 2024 | 07:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
what year truck?
randyein
Oct 8, 2020 03:59 PM
jah65
Jan 20, 2011 04:26 PM
Ak68F250
Jul 13, 2010 10:20 PM
Nyborg
Aug 7, 2008 12:28 PM
cj5968
Sep 22, 2007 12:59 PM
