Possible engine build
Old Aug 3, 2005 | 08:28 PM
iron_man1085's Avatar
iron_man1085
So I've been thinking of building a 5.4 w/ 4v heads ot put in a car, maybe start with a navigator engine out of a wreck. Just a few questions;
1. Any aluminium 5.4 blocks available and if not can I use the 4.6(cant remember if they're the same thing)
2. What would be my best bet for 4v heads
3. What the H... am I gonna do about an intake manifold
Thanks for any help guys.
Old Aug 4, 2005 | 05:56 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Please read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Aug 6, 2005 | 04:38 PM
coalminer78's Avatar
coalminer78
1. try www.worldcastings.com
cant answer the rest
Old Aug 6, 2005 | 04:43 PM
Spaznaut's Avatar
Spaznaut
I was thinking that the shock towers had to be modified depending on the car. They are wider than a 460. Would be a great hot-rod project. Stick a nice supercharger on top and weeeeeee off ya go.
Old Aug 6, 2005 | 06:41 PM
fordboy_52's Avatar
fordboy_52
are you going fuel injected or carb setup?
Matt
Old Aug 7, 2005 | 12:56 AM
iron_man1085
The car its theoretically going into already has a modular in it and according to ford the 5.4 4v is only like an inch or 2 wider. This would be an injected electronically controlled engine.
Old Aug 11, 2005 | 11:22 AM
iron_man1085
Another question: are the mounts on the v10 the same as the modulars in the cars or are they different? I know the trucks are using frames as opposed to the cars which are unit-body, is that going to lead to a different mount?
00leveledlariat
Mar 10, 2024 01:03 PM
flyingtexan
Modular V8 (4.6L, 5.4L)
Dec 21, 2016 02:20 AM
Luckett35
Jul 28, 2016 05:36 PM
Tbone67
Jul 3, 2016 06:33 AM
flippers13
Jun 28, 2015 05:22 PM
