Bronco II Ford Bronco II
fuel problems
Old Jul 26, 2005 | 10:31 PM
silent.d's Avatar
silent.d
fuel problems
new to the forum here, seems to be much expertise here, hope you all can help out. have an 88 b2, 5 speed, 4x4. been sitting about 2 yrs, due to drivetrain problems. got that fixed. now, when driving, acceleratedes good, till high gear, then skips. changed fuel filter, drained tank. any help appreciated.
Old Jul 26, 2005 | 11:42 PM
RomerB2's Avatar
RomerB2
Welcome to FTE, there's a lot of people here that'll help you out.
Now for your problem.. have you pulled codes? Ken has posted how to pull codes. You should check it out, it's on the top under the Bronco II part.
Old Jul 27, 2005 | 08:01 PM
Ken00's Avatar
Ken00
Also check the fuel pressure.
Old Jul 28, 2005 | 06:50 AM
silent.d's Avatar
silent.d
can't remember the code number right off hand, but bottom line, it said the hego sensor indicated my fuel mix was lean. fuel pressure regulator or low pressure fuel pump, maybe?
Old Jul 28, 2005 | 09:59 AM
plilikoi's Avatar
plilikoi
If it's intermittent lean, only corresponding to the problem you describe, it could perhaps be a bad plug wire. The reasoning being that a bad plug wire could fail to provide an adequate spark under load. The unburnt HC's coming off that cylinder would cause the ECU (via the O2 sensor) to lean all cylinders to compensate.
Old Jul 29, 2005 | 10:10 AM
silent.d's Avatar
silent.d
new plugs, wires, dist. cap, rotor button also
Old Jul 29, 2005 | 01:48 PM
mrshorty's Avatar
mrshorty
There are three kinds of EEC-IV code: key on engine off (KOEO), continuous memory (CM), and key on engine running (KOER). O2 sensor can't effectively be tested KOEO, so an O2 sensor code can only show up in the KOER test, and in the CM codes (after separator pulse during KOEO test). I'm leading up to the question: is your O2 sensor code a KOER code, a CM code, or both? One caution about a KOER lean code: Be sure to preheat the O2 sensor (run the engine at operating temperature for a couple of minutes immediately before performing the test), or you will get a false KOER lean code. It can be easier to diagnose KOER codes becaue they represent hard faults that are present here and now. CM codes can point to intermittent faults, which can be harder to diagnose.
With just about any code, the first thing I would do is inspect the wiring between the EEC-IV computer and the indicated sensor. Check for breaks, loose connections, shorts, etc. Don't forget to include checking the computer grounds.
Old Jul 29, 2005 | 07:43 PM
silent.d's Avatar
silent.d
did the koer test per instructions in my computer code retrival book. ran the engine a couple minutes, turned off for 10 sec, restarted, goosed the accelerator at the appropiate time, read the codes. the only thing i haven't done is what ken suggested w/ the pressure, and i'm wondering, will the pressure guage tell me if it's the regulator or low press. pump?
Old Jul 30, 2005 | 05:22 AM
silent.d's Avatar
silent.d
With just about any code, the first thing I would do is inspect the wiring between the EEC-IV computer and the indicated sensor. Check for breaks, loose connections, shorts, etc. Don't forget to include checking the computer grounds.[/QUOTE]
where is the puter and hego sensor located??
Old Jul 30, 2005 | 10:15 AM
mrshorty's Avatar
mrshorty
Assuming your '88 is the same as my '87, the computer is behind the passenger kick panel, just below the glove box, just forward of the passenger door.
HEGO is in the exhaust "y" pipe where the two pipes come together just forward of the catalytic converter.
F-250 WARHORSE
Apr 29, 2014 06:41 AM
kd7ptn
Dec 4, 2010 01:00 PM
John Durant
Oct 25, 2007 12:07 PM
George_911
Electrical Systems/Wiring
Jul 6, 2005 12:36 PM
joezee
Bronco II
Oct 6, 2003 06:50 PM
