HELP!! Need fuel pump help
Old Apr 28, 2014 | 08:02 PM
F-250 WARHORSE's Avatar
F-250 WARHORSE
I need a front fuel pump for my 1996 f350 4x4 reg cab 5 spd for the midship tank, My problem is I don't know which one to order. Seems to be a few of them. Mine has 2 ports, steel, and original. How do I know if I have a 17 gallon midship or a 19 gallon midship? Is there a telltale thing here or do I just hope that the 2 port pump for 17 gallon is right and assume that the 19 gallon took a 3 port?
Old Apr 28, 2014 | 11:07 PM
roughridn_sob's Avatar
roughridn_sob
similar truck to yours I just replaced the front pump on my truck AIRTEX P/N E2059MN
I compared the 17 and 19 gal at the parts store and both where the same visually not sure what the differences are but the 17 was cheaper so thats what I got been running for a little over a month no problems
Old Apr 29, 2014 | 06:41 AM
F-250 WARHORSE
hmmm! that sounds interesting. Thanks for the input. I would guess the 17 gallon pump would fit either one; and the 19 gallon might be slightly longer getting it further into the tank? Like the 17 gallon pump in the 19 gallon tank would leave a little bit in the bottom, and the 19 gallon might not quite fit in the 17 gallon tank. Thanks.
Brain's 97 Diesel
Nov 4, 2016 06:27 PM
Beachboss
Jan 27, 2015 02:29 PM
moose94
Jul 19, 2004 12:18 PM
couleeman
Mar 9, 2003 10:44 PM
tmcalavy
Jul 11, 2000 02:40 PM
