1978 - 1996 Big Bronco
Tail-gate water leaking
Old Jul 26, 2005 | 04:38 PM
Encho's Avatar
Encho
The Southernmost Mod
Exclamation Tail-gate water leaking
Can anyone help me? whenever it rains water sips in the back, moisturing the cargo area carpet... it will have bad effects later, what can i replace or do to prevent this leaking...
P.S.: Thx for any suggestions you make
Old Jul 26, 2005 | 04:46 PM
slickerthanyou's Avatar
slickerthanyou
Couple of things- Replace the window wipes that keep water out cant remember what the real name is. And check your seal around tailgate- open it up and there is a rubber seal around the body if it's not smashed or split then it's ok. Also as these things are known for the bottom of the tailgate could be rusted out and water getting up there like mine! That's about all i can think of.-Bob
Old Jul 26, 2005 | 04:54 PM
Encho's Avatar
Encho
Thx Bob, i do have a some rust in the lower part of the door, but the leaking happens only when it rains.
P.S.: don´t worry about my door, i will either replace the lower part or change the entire door, and after that i will use Bed-liner, Rhino lining or any of that kind of products to protect it so that doesn´t happen again
Old Aug 19, 2005 | 10:16 AM
carriljc's Avatar
carriljc
RTV the access plate for the rear gate....
It doesn't rain much where I live, so when it rained and the back of my Bronco got wet I started looking around. I had recently removed the access plate to fix my rear window motor and just put it back together without sealant....turns out that's what it was. I just got some clear RTV and complete sealed around the access plate...no more inleakage.
Old Aug 19, 2005 | 10:21 AM
tigerhawk_212's Avatar
tigerhawk_212
the tailgate weatherstripping breaks and rots and lets water in. Replace it and make sure you have some duct tape or other kind of cover sealing the tailgate under the access panel.
Old Aug 19, 2005 | 02:41 PM
jem270's Avatar
jem270
I had to cut a piece of plastic and put it under the access panel to stop water from leaking on my carpet. I used caulk to hold the plastic in place.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old Sep 27, 2005 | 04:58 AM
joeMontana's Avatar
joeMontana
Weatherstri
ummm... where can i get this weatherstripping.Home Depot?Parts Store, Dealer? This is the only rotten thing on my truck.
thanks
Old Sep 27, 2005 | 05:41 AM
muckypaws's Avatar
muckypaws
bronco graveyard sell all the weatherstrips for your truck.
masseysbronco
May 10, 2010 09:34 PM
str8racing
Mar 30, 2010 05:33 PM
xtmsports
Jan 12, 2010 08:28 PM
redneckaggie2008
Dec 14, 2007 01:04 AM
Greg Carter
Sep 10, 2002 01:20 AM
