Tail-gate water leaking
Can anyone help me? whenever it rains water sips in the back, moisturing the cargo area carpet... it will have bad effects later, what can i replace or do to prevent this leaking...
P.S.: Thx for any suggestions you make |
Thx Bob, i do have a some rust in the lower part of the door, but the leaking happens only when it rains.
P.S.: donīt worry about my door, i will either replace the lower part or change the entire door, and after that i will use Bed-liner, Rhino lining or any of that kind of products to protect it so that doesnīt happen again |
RTV the access plate for the rear gate....
It doesn't rain much where I live, so when it rained and the back of my Bronco got wet I started looking around. I had recently removed the access plate to fix my rear window motor and just put it back together without sealant....turns out that's what it was. I just got some clear RTV and complete sealed around the access plate...no more inleakage.
the tailgate weatherstripping breaks and rots and lets water in. Replace it and make sure you have some duct tape or other kind of cover sealing the tailgate under the access panel.
I had to cut a piece of plastic and put it under the access panel to stop water from leaking on my carpet. I used caulk to hold the plastic in place.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles |
Weatherstri
the tailgate weatherstripping breaks and rots and lets water in. Replace it and make sure you have some duct tape or other kind of cover sealing the tailgate under the access panel. thanks |
bronco graveyard sell all the weatherstrips for your truck.
