Water leaking
Old Oct 12, 2007 | 04:47 PM
redneckaggie2008's Avatar
redneckaggie2008
Water leaking
I noticed a small water leak on my truck the other day and then today it just started pouring. I can't figure out what is leaking but i think its the water pump. The leak is coming from right by the crank pulley as far as I can see. Does anybody know if I am right/wrong any info is greatly appreciated.
Old Oct 12, 2007 | 07:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
That does sound like the water pump went south.
The only other option I can think of would be a split in the side of the lower radiator hose that is spraying coolant at the crank pulley.
Old Oct 13, 2007 | 12:23 AM
PLC7.3's Avatar
PLC7.3
The weep hole on the water pump main shaft seal is directly above the crank pulley..... use a mirror and see if there is a stained area around the hole..........
Old Oct 13, 2007 | 12:46 AM
David85's Avatar
David85
I had this happen to two diesels in as many weeks. First with a 6.5 turbo, and later with my 6.9. In both cases the pump gasket had failed at the bottom. Not sure how comon this is but from one day to the next you could see more leaking, but in both cases, the water pump was still good.
Old Oct 30, 2007 | 08:24 PM
Joetravelall's Avatar
Joetravelall
My truck started leaking last Wednesday, and today was the first time I got to look at it. It must be leaking out the weep hole or it could be the gasket. It is dripping down the front of the block onto the crank. If it is just the gasket would it in my best interest to replace the water pump anyway?
Old Oct 31, 2007 | 06:14 AM
mistakenID's Avatar
mistakenID
Joetravelall, if the pump is fairly new, I would just replace the gasket. If there is any question about the age of the pump, I would replace it. No sense in doing the gasket and then doing it all again...even if it lasted 2 more years, I'd still replace it.
But thats just me
This is the time of year when good old cold water leaks rear their ugly head.
Old Oct 31, 2007 | 09:31 PM
Dave Sponaugle
Check the water pump shaft for play in any direction.
If you have play, replace the water pump.
The fan clutch threads off the water pump shaft, left hand threads.
When I reinstall the fan clutch, I always put a couple drops of lock tite on the threads.
I did have one back off under deceleration, it made a very big hole in the radiator.
Old Oct 31, 2007 | 09:54 PM
knash0727's Avatar
knash0727
I had mine just run all the water out, but my block heater fell out.
Old Oct 31, 2007 | 11:27 PM
PLC7.3's Avatar
PLC7.3
If you guys need the correct R&R instructions for the water pump.. click on my name and email or PM me your email addy and ask for: water pump R&R info
Best to get the correct how too or you could kill the IP or damage the engine..
Old Dec 10, 2007 | 08:12 AM
Joetravelall
Plc7.3
PLC7.3 I have lost my privileges to email you for the water pump R&R. I've been out of town. If you would please email them to me. It has gone from a cup every couple of days to a gallon a day now. I need to get it done fast.
Thanks Joe
Old Dec 14, 2007 | 01:04 AM
klr's Avatar
klr
i would like to get the r&r water pump but cant email im a new member
mneal1105
Dec 2, 2014 06:24 PM
NBT22555
Jul 10, 2014 11:44 AM
Eddie C
Mar 10, 2014 11:09 AM
masseysbronco
May 10, 2010 09:34 PM
xtmsports
Jan 12, 2010 08:28 PM
