1978 - 1996 Big Bronco
Tail-gate water leaking
Old 07-26-2005, 04:38 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Exclamation Tail-gate water leaking
Can anyone help me? whenever it rains water sips in the back, moisturing the cargo area carpet... it will have bad effects later, what can i replace or do to prevent this leaking...
P.S.: Thx for any suggestions you make
Old 07-26-2005, 04:46 PM
slickerthanyou's Avatar
slickerthanyou
slickerthanyou is offline
Couple of things- Replace the window wipes that keep water out cant remember what the real name is. And check your seal around tailgate- open it up and there is a rubber seal around the body if it's not smashed or split then it's ok. Also as these things are known for the bottom of the tailgate could be rusted out and water getting up there like mine! That's about all i can think of.-Bob
Old 07-26-2005, 04:54 PM
Encho's Avatar
Encho
Encho is offline
Thx Bob, i do have a some rust in the lower part of the door, but the leaking happens only when it rains.
P.S.: don´t worry about my door, i will either replace the lower part or change the entire door, and after that i will use Bed-liner, Rhino lining or any of that kind of products to protect it so that doesn´t happen again
Old 08-19-2005, 10:16 AM
carriljc's Avatar
carriljc
carriljc is offline
RTV the access plate for the rear gate....
It doesn't rain much where I live, so when it rained and the back of my Bronco got wet I started looking around. I had recently removed the access plate to fix my rear window motor and just put it back together without sealant....turns out that's what it was. I just got some clear RTV and complete sealed around the access plate...no more inleakage.
Old 08-19-2005, 10:21 AM
tigerhawk_212's Avatar
tigerhawk_212
tigerhawk_212 is offline
the tailgate weatherstripping breaks and rots and lets water in. Replace it and make sure you have some duct tape or other kind of cover sealing the tailgate under the access panel.
Old 08-19-2005, 02:41 PM
jem270's Avatar
jem270
jem270 is offline
I had to cut a piece of plastic and put it under the access panel to stop water from leaking on my carpet. I used caulk to hold the plastic in place.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old 09-27-2005, 04:58 AM
joeMontana's Avatar
joeMontana
joeMontana is offline
Weatherstri
ummm... where can i get this weatherstripping.Home Depot?Parts Store, Dealer? This is the only rotten thing on my truck.
thanks
Old 09-27-2005, 05:41 AM
muckypaws's Avatar
muckypaws
muckypaws is offline
bronco graveyard sell all the weatherstrips for your truck.
masseysbronco
05-10-2010 09:34 PM
str8racing
03-30-2010 05:33 PM
xtmsports
1997-2006 Expedition & Navigator
01-12-2010 08:28 PM
redneckaggie2008
12-14-2007 01:04 AM
Greg Carter
09-10-2002 01:20 AM
Quick Reply: Tail-gate water leaking
