81 f100 4.9 water leak?
My 81 has the straight six, and I believe the SROD 4 speed manual tranny. I have water dripping down where the bellhousing meets the rear main seal. I though perhaps a freeze plug or the temp sender were leaking, but they are all dry. Can anyone tell me where in the world this water could be coming from? Surely water can't leak out of the rear main seal. There is no water in the oil, and it is definately water that is dripping out.
No, I checked for that. It is not even running right now, I have the gas tank out to replace the sending unit, and I noticed it while I was under there. I saw 4 freeze plugs on the passanger side and 1 on the back-all dry. I checked temp sender, and any area that might be funneling water from the front of the motor-all dry. I'm at a loss, and open to any suggestions....
Go to parts store and get a leak detector its a uv dye that you can put in the radiator and it comes with a little pin black light. Also try this link its with a 5.0 but same problem https://www.ford-trucks.com/forums/8...rear-main.html
Dan Drover
07-18-2014 12:18 PM
Dan Drover
07-15-2014 11:55 AM
