Need help with C6AE-U heads
Old Jul 22, 2005 | 03:37 PM
scamardo's Avatar
scamardo
Anyone have any flow numbers for the stock FE C6AE-U heads?
I am getting mine rebuilt right now and putting stainless steel CJ valves in them. The builder told me he would have to hog out the valve seat a little but they would be more durable than stock.
Trying to figure out what kind of hp/tq this thing will make as I am putting in a 33-238-4 CompCam (duration 262/270 Lift .513/520. with Performer RPM intake/Holley SA 670 and long tube headers. Got friends telling me to bank on around 350-360 hp but need better flow number info.
Any help is appreciated!
Old Jul 22, 2005 | 04:44 PM
rusty70f100's Avatar
rusty70f100
We need more information! What carb, what intake, what exhaust system, exactly how much compression, bore / stroke... I'm assuming it's a 390? I cant keep up with everyone's projects, so if you could refresh my memory. According to my book, those are high compression Mercury heads, with standard ports and valves. Should flow like a standard FE head.
I dont have numbers for those heads specifically, but I have numbers for D2TE-AA's, C8AE-H's, and C4AE-G's. There is a difference between the C4's and the C8's, as well as between the C8's and the D2's. The C4 flows the best, then the D2, then the C8. I dont know where yours is.
Old Jul 22, 2005 | 10:32 PM
scamardo's Avatar
scamardo
Here ya go Rusty.
Holley Street Avenger 670 cfm
Edelbrock Performer RPM intake
Long tube headers (Hooker)
9:5.1 compression ration
66 390 FE
C6 tranny
Stock bottom end
Stock heads C6AE-U. I appreciate any info. If you got some stock flow #'s that would be cool. Thanks again.
Old Jul 24, 2005 | 02:34 PM
rusty70f100
Alright, I'm showing 356hp @ 5000rpm, and 444ft-lbs @ 3000rpm. I looked up the port sizes, and the C6 heads apparently use the same port size as the C4's, so I ran it using the C4 head flow data.
Old Jul 24, 2005 | 07:42 PM
scamardo's Avatar
scamardo
Thanks Rusty. I appreciate the help. I have been looking all over the net for some one that knows the 66 head flow data, but it is hard to come by.
Thanks again
Old Jul 24, 2005 | 08:18 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Someone correct me if i'am wrong? In 65 1/2 to 66 they changed port size's..from the the large ports to smaller one's...
Russ.. i have too put the grandkid down..brb....
Old Jul 24, 2005 | 08:58 PM
rusty70f100
Well, the only indication I got was on DSC's web site. If I should run it with the smaller port heads, let me know!
Old Jul 25, 2005 | 08:25 AM
RapidRuss's Avatar
RapidRuss
Ok..I thought I was right? but started to second guess myself after a 12 pack and 3 shots of Franklin County Spring water?? LOL..
I went down to my Neighbors house...(he restores Ford Muscle cars for a living)
And here's what ya have..the C6AE-R's were the first heads to be used in the 67 Model year...and one of a few that are getting hard to find (because of us guys who like to hotrod!! and they have the Larger ports and the Higher Exhaust ports which relate to a better High perfomance head with CJ size Valve and Excellent Flow when Ported..
Now with that being said....the C6AE-U's and the C7AE-A's are a smaller port head and have a lower Exhaust port (lower Exhaust port being better for building Torque) But not as much flow (as would be needed for HP)
But can still be a good head with CJ Valve's and port work depending on your build...
I hope this Helps....
Russ
Old Jul 25, 2005 | 12:05 PM
rusty70f100
Aha! I'll run it with the C8AE-H flow data. That comes out to be 309hp @ 4500rpm, and 438ft-lbs @ 2000rpm.
With CJ valves, it's 327hp @ 4500rpm, and 439ft-lbs @ 2500rpm.
I do have flow data for a set of ported C8AE-H heads, so here we go with that:
With porting and the stock valves, it'll be 370hp @ 5000rpm, and 452ft-lbs @ 3500rpm.
With porting and CJ size valves, it'll be 388hp @ 5000rpm, and 456ft-lbs @ 3500rpm.
And just for farts and laughs, with the porting, CJ valves, and a Crane 343941 cam, it'd be 417hp @ 5500rpm, and 439ft-lbs @ 4000rpm.
Old Jul 25, 2005 | 01:14 PM
RapidRuss's Avatar
RapidRuss
Well just goes to show ya the whole Aray of builds....
Russ
fordtruck44
35
Sep 13, 2008 01:59 PM
73 ford guy
Jun 12, 2008 06:25 PM
jaydgraff
Mar 3, 2006 06:23 PM
scamardo
21
Feb 18, 2006 05:41 PM
kc8fhs
Oct 5, 2002 06:08 PM
