Efi 400
Old Jan 26, 2006 | 03:42 PM
  #76
Bill_Beyer's Avatar
Bill_Beyer
Ain't this a purdy piece!
http://www.coasthigh.com/Fuel%20Injection/spyder.htm
Old Jan 26, 2006 | 06:38 PM
  #77
danlee's Avatar
danlee
Just imagine two Power Elbows mounted on a 351C dual quad intake adapted to a stroked 400, with twin turbo's hooked up to two 80mm throttle bodies.
Old Mar 11, 2006 | 06:56 AM
  #78
danlee's Avatar
danlee
It's finally done!
I have had it out on the highway on a couple of occasions in the last week. It is very smooth running.
I don't think that I am getting the low end torque that I did with the carb, but that is due to the high rise single plane intake with large runners, versus the small runner Edelbrock Streetmaster that I had with the carb. It should have much better high RPM power. I haven't had much chance to check that out.
I will continue to tweak the tuning for a few more weeks, until I think that I am getting everything that I can get out of it.
Old Mar 11, 2006 | 11:48 AM
  #79
53fatfndr's Avatar
53fatfndr
Originally Posted by danlee
It's finally done!
Glad to hear it, Danlee
Old Mar 11, 2006 | 02:12 PM
  #80
Cutls67's Avatar
Cutls67
Hey hows it going I am new to this forum and have been reading on your efi build. I am also putting efi on my 78 400, but I am using a 351w intake from Typhoon and a set of adapters from Price Motorsport. I am going to use all 1990 mustang 5.0 harness and computer. I already have these items. I am more curious on your tuning chip. I am really only using mine for everyday use and towing. So I am not looking for all out performance (well maybe blowing some Duramaxes away). But I would appreciate any suggestions you might have. By the way looks good.
Stephan
Old Mar 11, 2006 | 03:49 PM
  #81
78bigbronco's Avatar
78bigbronco
Originally Posted by jopey
howell would be a far better choice if your lookig for tbi, $1200 with custom chip burnt for your engine. I would avoid holley stuff like the plege unless your going to get the top of the line commander setups.
Sorry been away for a while. So has anyone else used or heard much of the Howell kits? http://www.howell-efi.com/ck_tbi_index.html It appears to be complete minus a GM thorttle body. But the one thing it doesnt have is a laptop interface wich I really wanted. Programmability on the fly and also a computer display for tall the sensors/guages. What do you mean by "unless your going to get the top of the line commander setups"... what I was considering is Jegs
the 700cfm holley commander 950. But all the current kits available are commander 950's, so are they all the same or is on more 'top of the line' then another?
Old Mar 11, 2006 | 06:35 PM
  #82
danlee's Avatar
danlee
Stephan
I am using a Tweecer R/T. You can't just chip the ECU because of the increased displacement. I will use the Tweecer to get a couple of different tunes, and then burn a chip with the one that I like best.
Here are a couple of links.
http://fordfuelinjection.com/
http://www.tweecer.com/
Here is a nice setup.
http://www.mass-floefi.com/
Old Mar 11, 2006 | 06:41 PM
  #83
danlee's Avatar
danlee
I took the truck in a Parade today. The motor idled for more than an hour. The outside temperature was about 65 degrees, my motor stayed pegged at 180 degrees. The '72 Chebby with a carbed 350 in front of me had to rev his motor to clear it out. It was loading up from all the idling. I just let mine idle, after the parade was over, I gave it some gas and it took right off.
I don't think that I am optimzed yet, but it feels good and has good throttle response.
Old Mar 12, 2006 | 10:00 PM
  #84
go_racing84's Avatar
go_racing84
Real cool, man, you did a sweet job on that project.
Old Mar 13, 2006 | 09:31 AM
  #85
BroncoChuck's Avatar
BroncoChuck
WOW! Very impessive! I want something similar for my truck, but have a little problem: Is there any way to pass smog in CA with FI on s 351 / 400m?
Old Mar 13, 2006 | 01:03 PM
  #86
danlee's Avatar
danlee
It should be very smog friendly. You should be able to get a smog friendly tune.
Check with Jopes, he has posted in this thread. He has also done a conversion, and he lives in CA.
Old Mar 13, 2006 | 01:35 PM
  #87
roger dowty's Avatar
roger dowty
I was sure that you needed oem smog stuff in CA to pass visual insp. COunld be wrong but youd want to check it out.
Old Mar 13, 2006 | 05:26 PM
  #88
jopey's Avatar
jopey
best to check with a smog ref. they can let you know everything about it.
72fordgts
Apr 18, 2015 02:51 PM
relentless f100
Jul 22, 2014 10:54 PM
dfontana
New Member Introductions
Jul 16, 2013 04:48 PM
FossenRacing
21
Jul 21, 2011 12:45 PM
WILDFIRE16
Aug 25, 2004 07:58 PM
