Motor trouble?
Old Mar 6, 2006 | 09:02 AM
BigBody's Avatar
BigBody
Motor trouble?
Well, I've got a 77' F-100 with a 400. It hasn't been starting very good lately. You can here the starter turning the flywheel but it won't fire. But, none the less I've got it to start.
Well, today I'm driving it to work and it dies in the middle of driving 3 times. So, I finally get it home and get my other truck.
It was running fine and the truck had warmed up. Then out of no where those 3 times it would stumble and just shut off then my power steering would quit working.
Any ideas what could be wrong with it? The truck would fire back up after dying.
Thanks,
Kyle
Old Mar 6, 2006 | 09:29 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check the ignition module. A parts store can usually test them for free. Also check your timing. If it has changed significantly you may have a worn out timing chain that has skipped a tooth. There is a procedure for testing the ignition system and troubleshooting your engine in any aftermarket service manual.
Old Mar 6, 2006 | 01:07 PM
BigBody's Avatar
BigBody
After messing with it some more, it seems like the carb is flooding itself out. When you give it gas it stumbles. But, the carb settings have not chanegd since I had it tuned and its ran fine for months.
What could cause this? Would adjusting the carb even fix it?
Old Mar 6, 2006 | 01:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
Blown power valve. Typical with Holley type designs.
Old Mar 6, 2006 | 02:54 PM
BigBody's Avatar
BigBody
I believe its a carter carb. I know you said holley like design. Just putting that info out there.
How can you confirm if its the power valve? Where is the power valve on the carb? Can you buy a new one or do you have to buy a new carb?
Thanks,
Kyle
Old Mar 7, 2006 | 02:39 AM
Torque1st's Avatar
Torque1st
Posting Legend
If it is a stocker it has a power valve under the carb. Check in the carb forum for an exploded diagram or in your service manual.
Old Mar 7, 2006 | 07:22 AM
BigBody's Avatar
BigBody
The guys in the carb forum said if it was a power valve was bad it would idle rough. The idle is good. So, whats the next option?
Kyle
Old Mar 7, 2006 | 08:10 AM
Torque1st's Avatar
Torque1st
Posting Legend
Check my first post #2 in this thread.
Old Mar 7, 2006 | 09:14 AM
fastford59's Avatar
fastford59
Check to see if the floats are sticking,if the truck has been sitting for a while they might need the varnish cleaned off of them. Hope this helps...FF59
Old Mar 7, 2006 | 07:42 PM
danlee's Avatar
danlee
Check your fuel filter, it may be plugged. What you describe could be due to limited fuel flow.
Check your fuel pressure, it could be a bad pump.
If it is flooding you should smell gas, also look at the plugs. Flooding will cause fouled plugs.
Old Mar 7, 2006 | 08:54 PM
BigBody's Avatar
BigBody
I got Friday off so I'll look into and see what I find.
Thanks for all the opinions. If you ahve any more ideas send them my way. I'll let you know what I find.
Kyle
Old Mar 10, 2006 | 03:05 PM
BigBody's Avatar
BigBody
Well... Looks like the acclerator pump broke. Not to mention its leaking gas from aorund the elctric choke area and udner the idle adjustment screw.
I think I'd be better off going with a new carb. This one has seen better days. What do you guys reccommend for performance? I'd like to go with edelbrock.
Thanks,
Kyle
Old Mar 10, 2006 | 03:19 PM
BigBody's Avatar
BigBody
I said edelbrock but this looks like a nice carb. It doesn't even have power valves, or accelerator pumps.
http://store.summitracing.com/defaul...h.asp&x=39&y=6
Old Mar 10, 2006 | 03:30 PM
tastyklair's Avatar
tastyklair
The link you posted does't take you to a specific carb. Anyway, if you have a 4bbl, which I assume you do by the way you have talked, then an Edelbrock 1406 would be the ticket. Very simple to get running properly. Depending on what mods your engine has you may be able to put it on, adjust the idle speed and mixture and forget it. I use one on my modified 400 and had to change some jetting, metering rods and squirters to get it right, but it did run ok right out of the box.
Old Mar 10, 2006 | 03:46 PM
BigBody's Avatar
BigBody
HLY-0-80452
Holley Model 4160 Adjustable Float Carburetors How does this carb sound?
Yes you are correct it does have a 4 barrel holley intake.
I'll look into the 1406. Had one on my old ramcharger and could never keep it form dying when you'd punch it too the floor. But, that truck had lots of other problems.
Just looking for a couple options.
Thanks,
Kyle
