Sponsored by: Auxito
Power Window Help
Old Jun 29, 2005 | 12:00 PM
F150inOhio's Avatar
F150inOhio
Power Window Help
I have a 2000 F150 with a slow drivers side window. The window goes down about half-way normally and then almost stops for about 3 inches. After that it works fine untill I try to put it back up. The window will go about half up then creep for 3-4 inches then go up normally. The passenger side works fine. Please help me.
Old Jun 29, 2005 | 12:12 PM
furrby's Avatar
furrby
the only thing i know to do. is to oil or grease the motor gears. you can also put just a little oil in the window track.
furrby
Old Jun 29, 2005 | 01:08 PM
lancekilgore's Avatar
lancekilgore
use a silicone base substance, and line it on the window trackwhere the window rides up and down. Alot of times this help from the window getting stuck in the track. Normally fixes the problem. don't use oil or grease it will attract dirt and worsten the situation. Mine sticks and drags too, just got to get my lazy but out there and put the silocone on the track.
Lance
teamlx88
Feb 2, 2014 03:34 PM
rpeake
2004 - 2008 F150
Sep 19, 2011 07:47 PM
shaneBo
1997 - 2003 F150
Jun 23, 2008 03:47 AM
fsuranger
Electrical Systems/Wiring
Jul 17, 2004 09:28 AM
