I have a 2003 F-150 the drivers side window will not
go up or down (power windows). When I push the window button, there's a
click noise and the window doesn't move.
This just happened one day, the window was working just fine.
Welcome to FTE shaneBo! It may simply need the window track lubed so that the window doesn't bind up. Otherwise, the problem could be the motor or the switch. Hard to tell without doing some troubleshooting. Someone with a little more experience with this will be along soon. Good luck!
