Window Motor Problems
Old Jul 16, 2004 | 02:27 PM
fsuranger's Avatar
fsuranger
I have a couple of questions about the window motors in my 2000 F150 lariat. My driver side window goes down with no problem but makes a boing sound about 6 times on the way down, kinda like a spring constantly releasing. The passenger side goes down fine for about 4 inches and then slows down really bad for and then speeds back up to normal. It goes up completely fine though. I have never had power windows before so these problems are new to me. Is it the tracks on the passenger side. How can I fix these problems? Thanks for the help.
Ryan
Old Jul 16, 2004 | 05:47 PM
HomerWinzlow's Avatar
HomerWinzlow
The spring noise is common on the F150/Expeditions. Sometimes you can aleviate it by lubricating the regulator tracks but often the only way to get rid of it is to replace the regulator. Unless it is real aggrevating I wouldnt spend the coin on it.
The other one sounds like it is binding in the window run. Try lubricating the window run with dry silicone spray, which you can purchase at the auto parts store. Ford replaced a lot of the early window runs for binding. What I do is lubricate the run real good, then run the window up about 3 inches and then grasp the glass and work it side to side and then forward and back, and then raise it 3 inches and repeat over and over till its all the way up. This often will free it up well enough. You can also remove the door panel if binding persists and loosen the bolt at the botton of each side of the window run and adjust it outboard a little to relieve some of the binding.
Old Jul 17, 2004 | 09:28 AM
fsuranger's Avatar
fsuranger
Thanks for the help. I'll try it as soon as our company leaves. which wont be soon enough
krl13
20
Mar 22, 2017 11:31 AM
bf5113x
Oct 19, 2015 07:02 PM
Jt00
1983 - 2012 Ranger & B-Series
Aug 19, 2015 09:33 AM
BC1958
May 17, 2014 08:50 AM
TicoTube
1978 - 1996 Big Bronco
19
May 3, 2013 03:03 PM
