Offroad & 4x4
Another how much lift question
Old Jun 14, 2005 | 06:33 PM
  #31
Skipped_link's Avatar
Skipped_link
You think I cn get some 20" spinners for the michelines
Kabota, If it makes you feel any better the 49' is running minimal lift for 44" tires & enough fender trimming for 16" of travel,
I'm diggin all the EXTR3ME Ideas you all have but as for as somthing I would actually do, what are your oppinions of the raised spring pearches with the incorporated link mount?
Also how much hight is gained with the inverted shackle (shackle flip) on the rear springs?
Old Jun 14, 2005 | 06:53 PM
  #32
RawPower's Avatar
RawPower
3" if you use the same hanger, 6.5" if you use a front spring hanger (off the rear leaf mount of another truck) and put the shackle in it.
I seriously wouldnt go over 4" for the spring perch... 8" lift leaf packs/4" spring perches are better than the 6" perches/6" leaves... youre not gonna be flexin anyways...
you might also want to consider bumpstops in the rear because when you pull someone out it will pull the rear of the truck down (compressing hte suspension) and possible send the tires to meet Aunty Fenderwell.
will2045
1978 - 1996 Big Bronco
Feb 13, 2012 02:17 PM
bcaughhorn
Nov 15, 2010 11:54 AM
highboy1975
Offroad & 4x4
Sep 21, 2009 10:48 AM
reed1951
Oct 30, 2006 11:00 PM
led sled
Jun 2, 2004 09:26 AM
