Timing cover gasket replacement
Old Jun 2, 2005 | 11:46 PM
DDD's Avatar
DDD
I have an 1994 F150 5.0, 5 speed,97,556miles on the I have a small leak at the top of the cover.I can see the pool of coolant on top between the water pump. I am fairly mechanical and can follow directions. the Chilton illustration does not offer much.I want to know is there any thing special about doing this procedure or/and anything else I should knowsuch as removal procedures things to look out for=)etc.
Donavan
Old Jun 3, 2005 | 06:06 AM
frederic's Avatar
frederic
its straight forward. Strip the front of the engine, replace the gasket, reassemble in the reverse order you removed stuff.
Just watch the water pump bolts and accessory bolts... there are several different lengths there. Use ziploc bags if you want to keep it easy.
Old Jun 3, 2005 | 07:40 AM
DDD's Avatar
DDD
Once again Mr.F Thank you.perhaps if they offered paid positions you would be a millionaire.
Donavan
Old Jun 3, 2005 | 08:47 AM
95X15's Avatar
95X15
Check the timing chain while you are in there- factory spec for replace is 0.50 in deflection or 0.12 slack measured along the chain. For reference the new NAPA timing chain set had zero slack prior to running and I didn't check it since it has been run too much trouble. Mine had more slack/deflection than I thought it should have for 115k so i replaced it while the cover was off. One more consideration to ponder.
Old Jun 3, 2005 | 04:39 PM
EPNCSU2006's Avatar
EPNCSU2006
Even if the timing chain is within spec, it might still be a good idea to spend 20 bucks on a new timing set (gears and chain) while you have easy access.
Old Jun 4, 2005 | 09:21 AM
90f150moneypit's Avatar
90f150moneypit
Yes, replace it!
After going through the trouble of swapping cams.................I missed work yesterday and got a ride home.......broken timing chain.
FWIW
If you see a puddle on the top of the cover, it's more than likely NOT the cover leaking. Check everything (hoses etc) above it first.
Old Jun 4, 2005 | 09:53 AM
MustangGT221's Avatar
MustangGT221
Moved to appropriate forum.
Old Jun 4, 2005 | 03:19 PM
95X15's Avatar
95X15
Agree with Moneypit - if you see leakage on top of timing cover it could easily be bypass hose. thermostat. throttle body coolant lines or even intake manifold. Sorry I missed that the first time; it would be a shame to do that much work and find it was something else and still leaking. FWIW - mine was leaking at bottom of the ears where the long water pump bolts go into block and was running down to pan along pan gasket and dripping off rear of engine/front of engine depending on the angle the truck was parked. Good luck.
svt2205
2009 - 2014 F150
21
Sep 19, 2014 04:07 AM
greasemanicure
26
Sep 7, 2011 10:08 PM
lmrapp
Nov 1, 2007 02:02 PM
02GrayPowerStroke
Jul 4, 2005 09:04 AM
elk
Mar 18, 2005 09:06 AM
