Squeak is driving me CRAZY!
Old Apr 29, 2005 | 12:37 AM
Panzermitch's Avatar
Panzermitch
Guys, I've been chasing an annoying squeak in the steering column on my '76 F-250. I've read here before that some squeaks originate just under the steering wheel. I pulled it and lubed the contact point. (My horn is a button on the dash, so no need for the contact ring.) Then I applied military grade CLP, (Cleaner Lubricant Preservative) around the opening where the shaft emerges. I worked the column left and right many times, lubing as I went along. Even after all of that I still have a fingernails on the blackboard squeak. Any ideas? All help appreciated! Mitch
Old Apr 29, 2005 | 01:52 AM
deisele75's Avatar
deisele75
If the sweek is really that bad you probably have some worn out internals. The easiest fix would probably be to get another steering column.
Old Apr 29, 2005 | 10:04 PM
tjay460's Avatar
tjay460
I don't know if the 76 is the same but in the 78 there is a small ball bearing and snap ring under the turn signal switch assy. that supports the steering shaft. Maybe the bearing is dry or failed. The bearing in mine is only open to the bottom side and thus spray lube from the top would not reach it. Mine is also an automatic if that matters.
Just my 2c
Old May 8, 2005 | 08:06 PM
Panzermitch
Thumbs up Thanks guys for the tips!
I appreciate both feedbacks. I'll be looking for the snap ring and bearing, and if that doesn't fix the problem, I'll replace the $%@$@#$ steering column.
Again, Thanks guys!
Panzer
Old May 8, 2005 | 08:34 PM
7fords's Avatar
7fords
check the steering column mounting bolts. i had a squeek that i thought was in my column but traced to the bolts
Old May 8, 2005 | 08:53 PM
Mil1ion's Avatar
Mil1ion
You would be better off squeezing some graphite grease in that bearing.
The bearing case is so tight allowances,reg grease will never work it's way in.
Old May 9, 2005 | 09:47 AM
beartracks's Avatar
beartracks
I placed a thin washer on top of the bearing to space the steering wheel collor off of the column where it was rubbing.
Old Feb 1, 2006 | 08:00 PM
Panzermitch
Those are great ideas. I'll try them.
Much appreciated!
Old Feb 1, 2006 | 08:52 PM
Torque1st's Avatar
Torque1st
Posting Legend
A dry bearing is usually ruined inside. Replacements are available from any bearing supply store.
BlackBeest
6.7L Power Stroke Diesel
Jan 26, 2019 08:46 PM
Elmo154
Sep 30, 2014 11:30 AM
AkF250HD
Aug 7, 2013 06:31 PM
jdenny21
Aug 28, 2012 11:04 PM
Glockem45
Apr 4, 2012 05:24 PM
