Squeek in steering column when turning
Old Apr 9, 2014 | 09:53 AM
Elmo154's Avatar
Elmo154
I have a squeak that developed in the steering column whenever I turn the wheel. It is as if something lacks lubrication. It does it in all steering positions. I guess next step is to open it up and see if I can get closer to the source so I can hit it with WD40.
Anyone else have this problem.
Old Apr 9, 2014 | 12:26 PM
Stewart_H's Avatar
Stewart_H
My F250 does this too. It hasn't bothered me enough to look into it yet.
Stewart
Old Apr 9, 2014 | 01:48 PM
rougerocco's Avatar
rougerocco
Mine is doing it too! After this very nasty and salty winter I am sure it needs some lube somewhere. I tried inside on the steering column and outside(which was a spray and pray I hit it) Couldn't see it very well.
Still making squeek
Old Apr 9, 2014 | 10:02 PM
gfl's Avatar
gfl
Before you tear into the column, try lubing the rubber where the shaft goes thru the floorboard
Old Apr 17, 2014 | 04:29 PM
Elmo154's Avatar
Elmo154
Rubber Shaft Lube
Ok, I lubed the rubber shaft going through the firewall and this seems to have fixed 90% of the rub and noise. Thanks!
Old Apr 17, 2014 | 05:44 PM
Stewart_H's Avatar
Stewart_H
Reps for the follow-up post.
Stewart
Old Sep 30, 2014 | 11:30 AM
truckingranny's Avatar
truckingranny
My F350 Super Duty just developed this squeak right after putting new brake pads on the front. Does anyone know if there is a connection, or should I just try lubing as suggested?
blockheadbob
Jul 17, 2005 03:11 PM
