Need to machine a small engine crankshaft
Old Apr 24, 2005 | 07:09 PM
RyanMiller's Avatar
RyanMiller
Hi, I'm working on 2 generators. One has a blown engine( no oil, broken con rod, killed cyl/ crank) The other has a blown gen head. I'm trying to put the good engine on the good gen head, but the good engine has a differnt shaft. it has a solid about 1 inch shaft with large threads at the end. the required shaft has a taper on it. Can I bring a crankshaft to a machineist and have a taper machined on, or would I be better off trying to get a new crank. How much would I expect to pay for a shaft turning? All thats required is to put the correct taper in, drill one hole and put threads in it. I could even thread the hole myself.
OR i was thinking I could do some redneck engineering and run the engine and hole some sandpaper untill it got the right taper! haha!
Old Apr 24, 2005 | 07:38 PM
RoyalFord's Avatar
RoyalFord
Take it to a machineist. But I wouldn't try the redneck way. lol. Or you could by a new one. What kind of generator?
Old Apr 24, 2005 | 08:32 PM
Greywolf's Avatar
Greywolf
I take it they don't use pulleys to connect the gen and engine...
Old Apr 24, 2005 | 09:17 PM
RyanMiller's Avatar
RyanMiller
The blown engine gen was a Coleman, the Good engine was a Kohler. Both engines are briggs. both around 5000 watts
Iv seen the cranks go for around 50 bucks. , and I think a machinest would be cheaper.. I'll make some calls tomorrow.
They are bolted directly to the engine, no belts.
Old Apr 24, 2005 | 09:29 PM
Greywolf's Avatar
Greywolf
Pity.
Pelts and pulleys would have been less expensive.
Old Apr 25, 2005 | 07:25 AM
RoyalFord's Avatar
RoyalFord
Let us know how it goes.
Old Apr 25, 2005 | 10:30 PM
StorminMarv's Avatar
StorminMarv
What are the rated HP on the engines? If they are 8hp or above the straight shaft is usually 1", the tapered saft is usually 30mm (the straight shaft might be too small). If you can pick up a crank for $50 you might be better off that way. Most shops around here would cahrge WAY more than that to turn it down.
Old Apr 26, 2005 | 08:36 AM
Silver Streak's Avatar
Silver Streak
Getting a taper turned on a crank and having a hole drilled and tapped in the end will be a bit more than $50. Don't they have couplers between the engine and generator? Lots of times you can get different coupler halves to work together.
Old Apr 26, 2005 | 06:43 PM
RyanMiller's Avatar
RyanMiller
I pulled the crank out of the engine, the shaft is aboue 1/2 inch too short. I'm gonna look into having a adapter made that would slide over the old shaft and then have the correct length taper.
Both are 8's
Old Apr 26, 2005 | 08:56 PM
RoyalFord's Avatar
RoyalFord
Sounds like a good idea.
You could just buy a new generator...
Old Apr 27, 2005 | 07:08 AM
350z's Avatar
350z
The two push mowers that i own were in my neighbors front yards for garbage pick-up,i got my tractor went down the road to each house grabed the handles and pulled them home , each one has a craftsman 4hp tech. motor,each had bent cranks,ordered the cranks and case gaskets from sears ,cost 48.00 ea plus the cost for a new blade,4 years later they still run great!
Old Apr 27, 2005 | 07:39 AM
RoyalFord's Avatar
RoyalFord
Haha, thats cool. People always throw away small 1 cyl engines. I see so many when I go drop stuff off at the dump.
herman391
Apr 16, 2008 02:52 PM
Hi Ho
18
Aug 24, 2003 10:28 PM
punkndrublic
Mar 28, 2003 10:28 AM
Fun in a Ford
38
Mar 24, 2002 04:26 PM
