Fuel door removal
Old Apr 7, 2005 | 09:45 PM
frdtruc1's Avatar
frdtruc1
Fuel door removal
1989 F150 fuel door is bent. Tried to remove it and stymied. It is riveted in, so I put the screw driver away. It has a pin in the hinge, but doesn't seem to want to slide out as it appears to be crimped at both ends. I can easily remove the spring but that is all. Should I cut the pin and get a new one to install the replacement. What am I doing wrong here?
Old Apr 8, 2005 | 07:42 PM
frdtruc1's Avatar
frdtruc1
Figured it out. Cut the pin and found a similar pin which I just crimped the ends and it works fine.
Gwilkrrs
22
Dec 11, 2023 02:38 PM
Woodsman_30350
Oct 8, 2018 07:16 PM
psycoreefer
Aug 28, 2015 11:38 AM
48fordcoe
15
May 21, 2012 05:33 PM
jefxxo
Jul 28, 2009 09:46 PM
