lighting problem
Old Apr 2, 2005 | 11:34 PM
1991fseries's Avatar
1991fseries
lighting problem
I have a 69 f-250 camper specail, my problem is that when the cab lights are connected to the harness the headlights don't work, I have a feeling that it might be a a ground problem, but don't know where to start looking any suggestions?
Old Apr 5, 2005 | 07:27 PM
1991fseries
anyone have any ideas
Old Apr 5, 2005 | 08:12 PM
4Cammer72's Avatar
4Cammer72
be a little more specific. do you mean the dash lights in the cab or the courtesy lights or all the interior lights?
Old Apr 6, 2005 | 07:39 AM
1991fseries
I mean the cab lights on the roof, when they are pluged into the harness the headlights and the dash lights don't work
Old Apr 6, 2005 | 07:48 AM
4Cammer72's Avatar
4Cammer72
do the lights on the roof work when plugged in? try a seperate lead from the fuse box to test the harness for the roof. its either a short in that or like you said a ground.
Old Apr 6, 2005 | 02:26 PM
1991fseries
yes the roof lights do work when they are plugged in
Old Apr 6, 2005 | 02:56 PM
4Cammer72's Avatar
4Cammer72
do the cab lights have a seperate switch or do they work off the same as the running lights . also if its the same switch if you just turn on the running lights without the headlights do the cab and running lights both work?
Old Apr 10, 2005 | 02:04 PM
1991fseries
It's the same switch for both, I'll have to check weather or not the running lights work with the cab light, I want to say the do but i have to check
bigfiretruck
2004 - 2008 F150
Mar 12, 2014 10:54 PM
bibababy
Mar 11, 2012 06:10 AM
Wicked Endings
Nov 28, 2010 10:34 PM
dodgeny
Mar 17, 2007 02:46 PM
Nash Green
Jan 15, 2004 10:41 PM
